  New Posts New Posts RSS Feed: Any thoughts on battery isolator
Topic ClosedAny thoughts on battery isolator
Direct Link To This Post Topic: Any thoughts on battery isolator
    Posted: 30 Oct 2014 at 8:19am
Learned it the hard way with my 2010 Suburban during a dry camp.  Since I had my genset I got a quick charge and was on the road within 15 minutes, but I'm more cautious now.
CharlieM View Drop Down
Direct Link To This Post Posted: 29 Oct 2014 at 8:10pm
Newer GM vehicles don't kill the Bargeman when the vehicle is off.
Are you sure about this, Doug? Is this yet another step backwards? What can be the thinking here?
Direct Link To This Post Posted: 29 Oct 2014 at 7:28pm
If you are using 12 volt mode on the fridge and will be stopped more than 60 minutes I would flip the fridge to LP mode.  That said, I'm with Charlie and preferred LP mode most of the time anyway.  Larger camper fridges only have LP mode when on the road, no 12 volt mode.
Direct Link To This Post Posted: 29 Oct 2014 at 4:28pm
Most relatively new trucks and SUVs have battery isolation built in. Assuming your truck has the standard 7-way round RV connector you can test this function with a voltmeter. Here's the wiring of the plug:
With the trailer disconnected and the engine running you should see around 13V between pin 4 and the truck frame. This should go to zero volts when you shut the engine off. If this checks out the truck will charge the camper battery while running, but the camper will not discharge the truck battery when the engine is off. There is no isolator in the trailer.
BTW, most folks prefer to run the fridge on propane while traveling. Contrary to old info, there is no safety issue. New gas bottles have limiting valves to prevent fire in case of accident. Using propane helps to maintain the trailer battery charge and the smaller fridges perform better on gas.
Trinityfly View Drop Down
Direct Link To This Post Posted: 29 Oct 2014 at 1:52pm
This has been cross posted with the FR Users Group
We have recently purchased a 2015 RPod 179. Have had other RVs that had a battery isolator installed between the tow vehicle and the coach.  As far as I know there is none on either my truck or the RPod. All the trailer manuals recommend using the 12 volt system to operate the refrigerator while traveling. If we have to stop for any length of time do we need to unplug the Rpod from the tow vehicle. If not does the coach battery draw off the auto battery? Any thoughts?
Joe and Diane, pups Jenny and Tyke. RPod named Lilly.
Alive and well deep in the toolies of Norther Calif
