Forum Home Forum Home > R-pod Discussion Forums > Dealer Reviews and Comments
  New Posts New Posts RSS Feed: Stoltzfus in Adamstown PA
Topic ClosedStoltzfus in Adamstown PA
Direct Link To This Post Topic: Stoltzfus in Adamstown PA
    Posted: 22 Jul 2015 at 9:09pm
Just find a local dealer to do your service.
Don Halas View Drop Down
Direct Link To This Post Posted: 22 Jul 2015 at 2:25pm
We had a good purchasing experience also with Stolzfus and Lee.  We travelled from Connecticut to Pennsylvania for a 2015 RP-178.
They offered a very competitive price, and we were taken good care of when we went to purchase the trailer and have the car prepped for towing.
I have a lot of respecect for Lee, he is a professional and clearly likes what he is doing and is looking out for the customers interests.  I would recommend them.
Direct Link To This Post Posted: 19 Oct 2014 at 11:05am
Just to throw my 2 cents worth about Stoltzfus...
Today marks our one year anniversary with our 2014 178 purchased from Stoltzfus. I can't speak about their service department other than the Reese WDH and brake controller setup. We haven't had it back for any service issues. Our purchasing and walkthrough experience was pleasant and thorough. We were novice RV purchases although I do have pretty extensive boat/yacht buying/surveying experience which maybe helps a little. I presented Stoltzfus with a quote from Couch's. They countered with a competitive quote and are considerably closer.
Subsequent and recent conversations with Stoltzfus regarding purchase of 6 year extended warranty were also pleasant and professional.
We've had a pretty good year of use from the Pod (about 10K miles) and have made a number of mods (see link in signature). The only thing I may have done differently when purchasing was to ask for Prodigy P3 brake controller vs. the Voyager installed and perhaps negotiated a credit for the battery, which I quickly replaced with dual 6 volt EGCs.
I do wish their was a close FR authorized service center if/when I need it. I'm not 100% confident with brakes/bearing inspection and repacking yet and wouldn't mind some professional guidance. Maybe I'll just do it when you all are around and upload pics as I do it. I am confident in the expertise of this group!
Cankicker View Drop Down
Direct Link To This Post Posted: 19 Oct 2014 at 10:22am
Originally posted by Luv2Q
On the Tundra, I'm still trying different combinations of speeds & gears to see what works best.  So far, it's been in the 11-13 mpg range.  Truck has the small v8 (4.6 L), 6 spd tranny and towing pkg (which includes 4.10 rear end) and a "tow/haul" switch.  It's rated to tow up to 8,000 and tows the 171 just fine.  But .. Very unpleasant to drive if I leave it in full automatic; downshifts/upshifts/downshifts if there's even a hint of a change in grade.  Kinda wish I'd opted for the 5.7 L motor.  Mileage likely wouldn't be a bit better but it might not hunt constantly for a different gear.
My 2013 Pathfinder (new model) has a CVT tranny, and I have been pleasantly surprised at how smooth it is. It is rated at 5000 lbs. with factory tow package. I added a WDH with anti-sway, and believe that allows for an increased tongue weight from 500 to 750 lbs (I read this somewhere.....)
I was at first a bit worried because like any CVT, it is a bit slower from a standstill to pickup speed, but it does just fine and there is no up/downshifting; just a smooth highway ride. The V6 engine struggles a bit on hills, but that was to be expected.
On another note, I am glad you had such a good experience with Stolz. The salesperson I worked with would not negotiate very much below the MSRP and I had to travel to Ohio from MD to buy my TT (I saved over $5,000 purchasing wholesale). I figure if anything goes wrong, I'll remove/repair/replace it myself after the mfg warranty expires.
Luv2Q View Drop Down
Direct Link To This Post Posted: 18 Oct 2014 at 11:02pm
Originally posted by Kickstart
Towing in tow/haul never worked for us, as this engine is small enough to not have enough torque to hold in 6th and sometimes 5th, which are both overdrives. This would then cause excessive shifting which would also indicate excessive transmission temps (according to my Scan/Gauge). We tow exclusively in S Mode 5th and S Mode 4th when it's hilly/windy. This stops so much towing in overdrive and really controls the trans temps. When pulling hard, this method bumps you up into the torque peak area of our engines which starts at about 2800 RPM, and helps minimize the shifting.
We recently returned from an extended trip to the SW (Utah, Arizona, Colorado). There were many tough pulls, and we spent additional time in S Mode 4th. The truck did great. Worst tank was 9.6 mpg and best was 12.8. Big engines? We don't need no stinkin' big engines!
Steve (& Jon) .. Thanks for the feedback.  I think you're right on staying out of o/d.  Plus, I'll probably try to spend a little more time in the 55-60 mph range.  Slower usually translates to a little better mpg.  And, after all, we didn't buy trailers (or trucks) with the idea that mpg is top priority.
John & Teri
Tundra 5.7L V8 / RP 180
Direct Link To This Post Posted: 18 Oct 2014 at 8:27pm
MES Pod, congrats on the new pod.  Several of us on the forum have purchased from Stoltzfus.  I was happy with my purchase, and for several years with their service.  However, you may want to consider using someone else for service.  See this thread:  http://www.rpod-owners.com/forum_posts.asp?TID=979&PN=1&title=stoltzfus-rv-in-adamstown-pa
MES Pod View Drop Down
Direct Link To This Post Posted: 18 Oct 2014 at 6:25pm
David and Danette,
Yea, he saved us a lot of problems, he really took the time to explaine rv and towing to us, it's a shame they are 3 hrs away. The electric line to the truck from the pod came loose and didn't notice it for a while and it ground down pretty bad, I called lee when we got home and a couple phone calls later because of the distance he wanted us to have the whole cable replaced at the box under the pod and send him the bill, that's customer service up and beyond in my book. We sure are looking towards next weekend when we can shake it down all by ourselves.
Ricky & Barbara
2021 Ford F-150, 2018 Pod 180
Budward View Drop Down
Direct Link To This Post Posted: 18 Oct 2014 at 5:35pm
Originally posted by Old Dingo&Mrs.Dingo
Everyone compares mileage, I have a good friend (engineer) who reminds me: "There is only so much energy in a gallon of fuel, and it doesn't care who's name is on the grill."
I agree!   My dad loves to tell about the guy in his motorhome club who always claimed he got 12mpg when all the other members were getting 9 or less!
So- one time on a long trip they were all stopping for gas together as a group.
Guess what- he put just as much gas in as everyone else!Embarrassed
2014 179
Kickstart View Drop Down
Direct Link To This Post Posted: 18 Oct 2014 at 12:47pm
But, maybe I just haven't found the driving combo it's happiest with.  Only have about 1,200 miles of towing with it so probably will learn some driving practices that work better.
It seems like I have the same truck/engine combo as you. I towed our Pod for over two years with ours, and am now towing a Kodiak that is about 1500 lbs more than the Pod. We've towed about 12,000 miles with the little engined Tundra and can give you an idea of what has worked for us.
Good luck with your Pod and Tundra. Even towing the extra weight of the Kodiak, I'm well satisfied with the job our truck does.
'12 Toyota Tundra
'05 Sportster (half a Harley)
Retired-We're on Beach Time!
Old Dingo&Mrs.Dingo View Drop Down
Direct Link To This Post Posted: 18 Oct 2014 at 12:29pm
Everyone compares mileage, I have a good friend (engineer) who reminds me: "There is only so much energy in a gallon of fuel, and it doesn't care who's name is on the grill."  Kinda explains why most of us get 10-12 mpg, I guess we must share similar driving habits.  (BTW, don't compare gasoline engine mileage with diesel mileage, there is more energy in a gallon of diesel fuel.)  Case in point:
I replaced my '08 5 speed Nissan Frontier with a '13 5.7 Grand Cherokee, there couldn't be any two TV that were more different.  They had much different drive train and body designs, one a pickup with a "ladder" frame, the other a unibody SUV.  One a OHC, 4 valve V6 with a 5 speed manual, the other a large pushrod V8 with an automatic.  The only thing they have in common is the weight, both were about 5000#.  The Jeep required a WDH to maintain the ride, I suppose the IRS is the reason, the Nissan had rear leaf springs and a live axle, it's ride wasn't affected, in fact it actually improved with the 'pod attached.  The point is, got the same mileage on both, but the Jeep is much quieter, never slows on a hill, or requires me to downshift, and that was the only change in my driving habits.  In fact I got the same mileage on both when they are solo too.
My driving habits; I drive with the cruise control on at 55-65 mph, I travel with empty black & gray tanks and 10 gallons in the fresh tank.  I load everything, including the "kitchen sink" in the 'pod and I'm near the weight limit Forest River suggests.  The best mileage I ever got: 13 in the Nissan and 12.9 in the Jeep.  Worst: 9 , in the Jeep traveling at 75 mph. (speed limit, I was in a real hurry Smile)
Old Dingo and/or Mrs. Dingo
181G
2013 Jeep Grand Cherokee
