Have You Done Any Mods?
 Post Reply Post Reply Page  <1 3132333435 52>
683 [81.41%]
10 [1.19%]
134 [15.97%]
10 [1.19%]
2 [0.24%]
You can not vote in this poll
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Topic: Have You Done Any Mods?
    Posted: 10 Sep 2014 at 1:50pm
Looks like it may be a pain to move the wires to a corner, but possible, then you would gain that back as storage space.
Webstas View Drop Down
Post Options Post Options   Quote Webstas Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2014 at 1:11pm
Originally posted by Webstas
I pulled the entertainment center out and there is nothing behind that panel, just wires.
(its a self signed cert ignore the warning)
I realized some people wouldn't want to click that, so i shrunk them and re posted them here. the full size images are still at the link above
Post Options Post Options   Quote Webstas Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2014 at 1:09pm
This is directly behind that panel
This is the ceiling direclty behind it
and some others
Post Options Post Options   Quote Webstas Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2014 at 1:04pm
In the one pic you can see where they screwed 2 screws in the same mounting hole in the bottom left corner Censored
Post Options Post Options   Quote Webstas Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2014 at 1:02pm
jeeperic View Drop Down
Post Options Post Options   Quote jeeperic Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2014 at 11:57am
there's an idea! Thanks.
That's the power button..press it.
Turn it all off.
Go outside!
'14 RPod 171
'09 Jeep Wrangler JK (mine)
'14 Dodge Ram 1500 4x4 (hers)
Hairy Podders View Drop Down
Post Options Post Options   Quote Hairy Podders Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2014 at 8:56pm
I would pull the stereo out & look up inside.....
Darryl, Julie & Lindsey
2014 RP178
Post Options Post Options   Quote jeeperic Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2014 at 5:59pm
hmmmm- the cabinet to the left isn't revealing anything, nor are there open shelves to the right facing the dinette. There's nothing on the outside of the Pod either. Sooooo- out comes the chainsaw!!!!! fine- a small exploratory hole...
Turn it all off.
Go outside!
'14 RPod 171
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2014 at 5:44pm
Interesting, on the older 171's that area is wider and completely open, from the bottom edge to the top.  It has elastic mesh on the front.  But, the entertainment unit was mounted underneath the cabinet and not in it.
Post Options Post Options   Quote jeeperic Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2014 at 1:29pm
'14 171
Turn it all off.
Go outside!
'14 RPod 171
