  New Posts New Posts RSS Feed: Break Light Flashes
Topic ClosedBreak Light Flashes - Event Date: 01 Sep 2014 - 10 Sep 2014
vnapoli View Drop Down
Direct Link To This Post Calendar Event: Break Light Flashes
    Posted: 01 Sep 2014 at 7:54pm
I have a 2014 RPOD 171 and on our recent trip my wife who was following me said that when I applied my breaks my left break light flashes as though I was making a turn. This only happen when the vehicle in running. In addition, the speed of the flashing is slower than a turn signal.
So my question is: Is the left one flashing when it shouldn't or is the right one not flashing when it should?
Thanks in advance.
Vince and Debbie
R Pod 171
Tacoma 4x4, regular cab, 4 cylinder
Hairy Podders View Drop Down
Direct Link To This Post Posted: 01 Sep 2014 at 9:12pm
Sounds like a bad logic module light controller on the truck. If yours has one. IE: If your truck has separate brake light & turn light bulbs on each side, then you truck has to have a logic module to adapt that system to the single brake/ turn light bulb on the Rpod. Sounds like that little black box is bad. Or it may have a poor ground.
Darryl, Julie & Lindsey
2014 RP178
Outbound View Drop Down
Direct Link To This Post Posted: 01 Sep 2014 at 9:32pm
If your running lights are on while you're breaking with the turnsignal, then yes, it might look like your description; but that'd be it.  Except, the flashing frequency shouldn't be noticeably slower - well, not on a truck built in this century (wow, it feels very strange saying that); a 90s truck's flasher might slow down a bit due to the voltage drop from powering all the lights.
Direct Link To This Post Posted: 02 Sep 2014 at 5:58pm
I agree it sounds like a problem with the tail/turn light combiner.  When mine went bad both brake lights flashed exactly like a turn signal.  Be careful to order a new one that supports LED lights, not all can drive LEDs.
Direct Link To This Post Posted: 02 Sep 2014 at 8:37pm
Thanks. The unit is under warranty so I'm expecting my dealer to replace it when I take it back for other warranty work.
Vince and Debbie
R Pod 171
Direct Link To This Post Posted: 03 Sep 2014 at 8:46am
This would be mounted on your tow vehicle, so not a pod warranty item.  However, if they installed it then I would ask them (or whoever did install it) to replace it.
Direct Link To This Post Posted: 07 Sep 2014 at 7:04am
I've isolated the problem to the truck by using my sons truck as a test and the brake lights on the RPOD don't flash.
The only black box I can find is the electric brake controller. Where do you think the combiner would be installed?
Vince and Debbie
R Pod 171
Direct Link To This Post Posted: 07 Sep 2014 at 7:09am
Start at the trailer plug on the truck & work your way forward following the wiring. Usually they are under the back of the vehicle. But it could be under the dash too.
2014 RP178
Direct Link To This Post Posted: 07 Sep 2014 at 7:19am
How large of a unit am I looking for? There is a flat wire going into the trailer plug. I originally had a 4 hire connector and when I got the RPOD they converted it to a 7 pin.
Vince and Debbie
R Pod 171
Direct Link To This Post Posted: 07 Sep 2014 at 11:07am
Approximately the size of a large pack of gum, and half as thick.
2014 RP178
