  New Posts New Posts RSS Feed: Spare Tire
Topic ClosedSpare Tire
mtbmitch View Drop Down
Direct Link To This Post Topic: Spare Tire
    Posted: 15 Aug 2014 at 11:52am
another spare tire location option
enjoy the fresh air
Direct Link To This Post Posted: 15 Aug 2014 at 11:50am
enjoy the fresh air
Direct Link To This Post Posted: 12 Aug 2014 at 11:20am
Sounds like a winner.  I wish the pods did the same to free up space on the front or back.
Direct Link To This Post Posted: 11 Aug 2014 at 7:40pm
    I built the frame today for storing the spare tire under the trailer. The tire is up under the trailer with about 8 1/2 " clearance under the frame. My measurements were a little off the tire is not centered on the frame but it will work. All I need to now is secure the tire to the frame, tomorrow I may do that. I thought about the sewer drain valves, with 7 1/2" ground clearance and twice the distance from the axle about 4'. They have not hit the ground yet so I was willing to take the chance with the spare with 8 1/2" ground clearance at 2' in the front of the axle. My 86 year old mother did not help my concern, she said what if the tire gets hit and it comes up through the floor of your camper. All I can say is I hope not!
2014 Ram 1500 Quad cab
Direct Link To This Post Posted: 10 Aug 2014 at 9:22pm
   Thank you TT for your reply. I no longer have a r-pod earlier this year we bought a Vibe similar frame and axle as the r-pods. Not sure if about 2' of distance in front of the axle will drop much when trailer is on a angle. You are right if I hit something and it broke lose the spare, it could be dangerous for us and anyone driving behind us. BAL " Hide-A-Spare " is used on different campers but haven't read anything on ground clearance yet. I will keep searching to see if I find anyone mentioning ground clearance.
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 10 Aug 2014 at 8:16pm
  Clearance at the axle is almost irrelevant.  As tires go over an obstacle the axle rises so it always has about 8 1/2" of clearance over any obstacle.  A lot may depend on the kind of camping you do.  I've nearly scraped off my drain pipe holder because of clearance issues.  Do you have a hitch on your pod?  I thought that was kind of standard location for the spare.  I want to move my spare somewhere else though so I can use the back for bikes.  Or I want to figure out something else for bikes, so I'll be interested in where you end up with this.  I tried a tongue mount but the spare won't fit due to my dual propane tanks.  I share your concern though about ground clearance with an underneath mount.  It could get really nasty if you hit something at any speed.
Direct Link To This Post Posted: 10 Aug 2014 at 3:23pm
   I am working on a plan to mount the spare tire under the trailer. It is similar to what Bal sells a hinged frame work that drops down on one side. The plan that I have will be placing the tire in front of the axle. The only thing I am little concerned with is the ground clearance, I don't think it will be a problem but not sure. The lowest part of the frame will have 8 1/2 " of ground clearance about 25" in front of the axle. Does any one think that would be a problem, the axle has about the same clearance 8 1/2" ?  Moving it would distribute the weight better for towing and provide more space in the cargo area.
