  New Posts New Posts RSS Feed: Storage under sink
Topic ClosedStorage under sink
Markus5 View Drop Down
Direct Link To This Post Topic: Storage under sink
    Posted: 04 Jul 2014 at 10:26pm
Nice.
prg4533 View Drop Down
Direct Link To This Post Posted: 04 Jul 2014 at 2:08pm
I just posted some pictures of my under sink mod here: http://www.rpod-owners.com/forum_posts.asp?TID=4926&KW=sink+storage&PID=47879&title=177-under-sink-dinette-space-valance-lights#47879
Fairly easy to do and reclaims tons of space.
jan demarinis View Drop Down
Direct Link To This Post Posted: 03 Jun 2014 at 4:34pm
Can you post some pictures please?
Thanks,
Jan
HappyCampers View Drop Down
Direct Link To This Post Posted: 03 Jun 2014 at 4:23pm
When we removed the panel that is there under the sink during our de-winterizing process, just to make sure everything looked OK, we were amazed at how much space there is under there!  We just left the back panel off and found that three of these fit in nicely:  http://www.sterilite.com/SelectProduct.html?id=473&view=0&picture=1&tab=Specifications&ProductCategory=250&section=1
One high in the very back, and two high in front of it.  THEN, there is still room for cereal boxes in front of those, along with all of our plates to the right of that.  Before that, all that fit there were our plates (in a vertical storage caddy).
Absolutely amazing how much more storage this simple mod made!  As the posters above mention, you just need to be mindful of the pipes, tubes, and wires under there, but definitely a highly recommended change.
ron_whitt View Drop Down
Direct Link To This Post Posted: 19 May 2014 at 8:38pm
markus, we have a 2012 177. We removed the panels under the sink, and I found a small plastic tub, it just fit over the relay switch and I notched out the ends for the wires to run, and also to let air flow through. I also put an outside shower there with the hoses fitting in that under sink area. You can store anything you want down there, with the panels gone you have a LOT of room.
Ron & Shirley
2020 Tacoma
2012 177 rpod
Direct Link To This Post Posted: 19 May 2014 at 8:26pm
I'll try it.
bodie55 View Drop Down
Direct Link To This Post Posted: 17 May 2014 at 4:00pm
Remove the panels.  We fit the kitchen cleaning supplies, small garbage can, cutting boards and flat griddle under there.  Just don't shove stuff back into the hoses.
Bay Area Crew
2013 178 Beach Pod
F-150 SuperCrew
...sempre in viaggio sul mare...
Direct Link To This Post Posted: 16 May 2014 at 7:45pm
On the road 177, the storage under the sink is really small. Anyone mod that area to get more storage?
