Budward
Topic: Battery Disconnect Posted: 16 May 2014 at 5:43am |
I always put a cutoff in the positive wire. Actually I use a DC circuit breaker that also functions as a switch.
2014 179
ToolmanJohn
Posted: 15 May 2014 at 10:02pm |
Originally posted by Markus5
Does the disconnect have any other effects that might not be expected? The breakaway note was appreciated. For example, will the clock go back 12:00? |
The microwave clock....Yes...It does on mine anyway. I keep a battery powered LCD alarm clock in the Pod. And my cell phone.
Also the propane detector will not work, it is run of the Pod battery, not a 9V battery like the smoke alarm.
Markus5
Posted: 15 May 2014 at 9:39pm |
Posted: 15 May 2014 at 8:31pm |
That's one reason I have a short checklist taped to the inside of one of the cabinet doors, one for just before taking off, one for when we get into camp.
ToolmanJohn
Posted: 15 May 2014 at 7:36pm |
Also just be aware, you will be disconnecting the positive feed for the trailer breakaway switch for the trailer brakes. Get a hard wired positive feed installed for your breakaway, if you tow with the positive (+) battery disconnect switch off, you have NO emergency trailer brakes.
cody91
Posted: 15 May 2014 at 1:53pm |
Thanks for the responses. It seems to me that there may also be advantages to connecting the switch to the negative side (i.e. reduced risk of sparks, etc.).
Posted: 15 May 2014 at 10:43am |
Positive, since the frame of the pod is connected to negative.
outermostpod
Posted: 15 May 2014 at 10:21am |
positive side because that's what the instructions said to do!
cody91
Posted: 15 May 2014 at 9:47am |
For those of you who have installed a battery disconnect switch on their Pod, which side of the battery terminal (Positive or Negative) did you install it on and why? Thanks, Cody91
