Page <1234> |
Hairy Podders ![]() Senior Member ![]() ![]() Joined: 05 Mar 2014 Location: Northwest Ohio Online Status: Offline Posts: 217 |
![]() Posted: 08 May 2014 at 7:55am |
...and as I said, I would source a waterproof one. Since they do not like water intrusion. If that is a factory part, I'll have to check our '14 178 for that breaker. I will be looking for a source for a waterproof one. Probably a marine supplier....
These old eyes aren't as bad as the wife says they are.... |
Darryl, Julie & Lindsey
Cooper & Libby- Devoted Canines 2014 RP178 2006 Wrangler Unlimited Rubicon |
Thanks again. Sometimes we don't know as much as we think we do.
Budward ![]() Senior Member ![]() Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
Personally I would hook to the load side of the breaker. That way your new wiring is protected too. |
2014 179
They open under an overload and self reset after a short time period, if the overload is still there they open again, and so on...
There are models that have to be manually reset- but the one FR uses in this app is self resetting. The same breakers are often used in electric brake wiring. http://www.cooperindustries.com/content/dam/public/bussmann/Transportation/Resources/catalog_pages/BUS_Tns_12X_Shortstop_CB.pdf |
2014 179
Ahhh, so thanks for the pointer Bud! It does, indeed appear to be a circuit breaker similar to:
I would guess it's an automatic reset thing. So in my install do you think it matters was side of the breaker my power leads should be? Good catch! fred |
That's interesting, Budward. When or how might that might trip and how would it be reset?
Thanks! fred
That is not a distribution block- it is a circuit breaker. On mine it is 50A.
I wouldn't have missed that ![]() |
2014 179
Thanks. I think I will pick up a can of the Permatex Battery Sealant .
Sound like good stuff and cheap insurance. fred
From the angle, it looked like a circuit breaker. I was hoping to avert any problems on your end.
What you are looking at is a power distribution block. It's not a fuse. Hot (red) from batteries on one side and main feed to WFCO panel on the other. That's all factory installed and sprayed with Permatex Sealent - the pink stuff.
The only change I made were the two white and two green wires terminated with the yellow ring connectors - white (positive) to distribution block and green (ground) to existing ground screw on frame. Simplest, shortest run for adding circuits to street side (slide side) of pod. Here's a closeup of the distribution block: [edit: as noted, it is a short stop circuit breaker, not distribution block] ![]() |
Page <1234> |
