Page <1234> |
![]() Posted: 07 May 2014 at 8:29am |
Looks like the light pink coating FR uses on and around the 12v distribution posts is Permatex Battery Protector and sealer. This looks like a good area that should be looked at occasionally. Most Pod owners probably don't even know it's there. I stumbled across it.
[edit: It's a short stop circuit breaker, not 12v distribution posts]
No, I didn't leave any fused connections outside the pod. The blade fuse holders are from local AC Delco auto store. Radio Shack only had the mini blade fuse holders. fred
Hairy Podders ![]() Senior Member ![]() ![]() Joined: 05 Mar 2014 Location: Northwest Ohio Online Status: Offline Posts: 217 |
Fred, In in the first picture of your post dated yesterday at 5:18pm & also the first picture of them all, it appears that there is a power feed wire & a couple of other wires bolted to two studs of a circuit breaker? That is what I'm referring to.
Darryl, Julie & Lindsey
Cooper & Libby- Devoted Canines 2014 RP178 2006 Wrangler Unlimited Rubicon |
What you are looking at is a power distribution block. It's not a fuse. Hot (red) from batteries on one side and main feed to WFCO panel on the other. That's all factory installed and sprayed with Permatex Sealent - the pink stuff.
The only change I made were the two white and two green wires terminated with the yellow ring connectors - white (positive) to distribution block and green (ground) to existing ground screw on frame. Simplest, shortest run for adding circuits to street side (slide side) of pod. Here's a closeup of the distribution block: [edit: as noted, it is a short stop circuit breaker, not distribution block] ![]() |
From the angle, it looked like a circuit breaker. I was hoping to avert any problems on your end.
Thanks. I think I will pick up a can of the Permatex Battery Sealant .
Sound like good stuff and cheap insurance. fred
Budward ![]() Senior Member ![]() Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
That is not a distribution block- it is a circuit breaker. On mine it is 50A.
I wouldn't have missed that ![]() |
2014 179
That's interesting, Budward. When or how might that might trip and how would it be reset?
Thanks! fred
Ahhh, so thanks for the pointer Bud! It does, indeed appear to be a circuit breaker similar to:
I would guess it's an automatic reset thing. So in my install do you think it matters was side of the breaker my power leads should be? Good catch! fred |
They open under an overload and self reset after a short time period, if the overload is still there they open again, and so on...
There are models that have to be manually reset- but the one FR uses in this app is self resetting. The same breakers are often used in electric brake wiring. http://www.cooperindustries.com/content/dam/public/bussmann/Transportation/Resources/catalog_pages/BUS_Tns_12X_Shortstop_CB.pdf |
2014 179
Personally I would hook to the load side of the breaker. That way your new wiring is protected too. |
2014 179
Page <1234> |
