Page 12> |
Author | ||
Hairy Podders ![]() Senior Member ![]() ![]() Joined: 05 Mar 2014 Location: Northwest Ohio Online Status: Offline Posts: 217 |
![]() Posted: 04 May 2014 at 6:54am |
On the 178, I'd would run wiring under the shower from the fuse panel back to under the edge of the bed for a 12 volt plug. That would be the easiest. On the '14 178 the inverter/fuse panel is just inside the entry door, at the base of the shower wall.
Darryl, Julie & Lindsey
Cooper & Libby- Devoted Canines 2014 RP178 2006 Wrangler Unlimited Rubicon |
OhTallMan ![]() Newbie ![]() ![]() Joined: 30 Mar 2014 Location: Columbus, Ohio Online Status: Offline Posts: 11 |
Good tips and ideas. Thanks so much for the advice.
______________________________
2014 Honda Ridgeline 2014 R-Pod 178 |
This has been pretty well covered. The only thing I can add is that if you don't particularly care where the 12v outlet is, your job will be a lot easier. I'd start at the fuse box and see what you can do easily. If you can get by with an outlet close to the box there may be almost nothing to it.
Most, if not all, of the interior walls are hollow and flimsy. It's not hard to get behind them but you have to be careful or you can mess things up. On my 176 the fuse box is at the bottom of the entertainment center and there is a lot of hollow wall there. I'd snake wires through rather than remove the panels if at all possible. I have run wires through the walls, so at least one of us does. I haven't installed a 12v outlet because I haul around a jumper box that has a 12v outlet on it. It will run just about anything for as long as I want, and I can move it wherever I need it. And if I run the TV or the pod battery down I've got essentially got a spare. I keep it plugged into shore power whenever possible to keep it ready to go. TT |
FJ Cruiser |
Outbound ![]() podders Helping podders - pHp ![]() ![]() Joined: 19 Nov 2009 Location: Oshawa, Ontario Online Status: Offline Posts: 767 |
I'd recommend not removing wall panels. It'll be a world of pain to get them back together. And, I'd avoid going under the trailer because of all the obstructions: the floor is insulated and the holding tanks are in the way; also, you'll be making holes in the protective membranes - sure, you'll silicone them up after you've run the wires, but that'll deteriorate in a couple years. In my 171, I've installed all outlets on the street side of the trailer, which is the side the converter is located, and for the most part I've run the wiring along the same path for existing wiring installed by the factory. I've installed:
I suggest that you just look around your trailer a bit, open a few access panels, pull out a few drawers, and get down on your hands and knees. Be creative. Think things through for ease-of-installation and ease-of-use before running a single wire or drilling a single hole. Oh - one more thing: for exterior power, I got creative/lazy. I installed a waterproof 12v outlet on the side of the battery box and connected the wires directly to the battery. That outlet is handy for plugging in my macerator pump, for plugging in an air pump to inflate the tires, for plugging in a 12v impact wrench to remove the wheels, and I'll occasionally plug in a boom box. Its actually very handy, and I'll likely do a similar install on every trailer I buy in the future.
Just to add to what Marwayne offered, there actually are a number of "panels" and access points through interior (bathroom) walls via vent at bottom of door, plumbing access panel (178) and panels at bottom of galley and even removing speakers or stereo unit gives interior bathroom wall access in my 178. The exterior walls are solid as is the floor.
Just a quick tip if you do remove any of the "panels" - they are all pretty thin 1/8" luan so it doesn't take much to hold them in place. It's very easy to over tighten fasteners, so go easy. If you are cutting a hole, probably a good idea to use a hole saw for a clean cut rather than a spade bit. If you can hold a piece of scrap wood on the backside of your hole cutout, it may help make a cleaner hole. When I have cut other shapes in the luan, I use a sharp utility knife and patience. As Marwayne has stated in the past, I've found course thread (drywall) screws to hold well in the solid walls. I will add a drop or two of adhesive when I can and I don't intend to remove. For the hollow walls and depending on the weight of what I am installing, I'll use a course screw, small molley or have even added a backing plate inside the wall. I know that's a lot more than you asked for. Hope it helps. Most importantly, just go slow and use all the common sense you got and don't forget to use the great search feature in this forum! fred
Budward ![]() Senior Member ![]() Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
In my best Steve Martin impersonation- Well EXCUUUUSSE me! By all means run them through your walls ![]() |
marwayne ![]() Senior Member ![]() ![]() Joined: 25 Oct 2011 Location: Edmonton AB Can Online Status: Offline Posts: 1004 |
Depends on where you want the outlets. If you want a plug in the dinette area you can run the wire around under the seats in the storage area. If you want it in the back by the bed I would run it from your power supply through the floor, bring it up through the floor by the bed. However if you run your wire under the trailer put it into a plastic tube for protection.
Thanks for your thoughtful short remarks, but that doesn't answer the question. I'd like to place some 12v outlets and am not sure how/where to run the wires. A polite and helpful answer from someone who has completed such a project would be appreciated.
No one is removing wall panels!
AFAIK they are bonded to the frame in a vacuum process. |
When you folks are adding these 12V outlets in various places, are you running wires through walls, underneath the unit, or what? If through walls, how easy/hard is it to remove wall panels to do so?
Page 12> |
