  New Posts New Posts RSS Feed: Bypass valves after winterizing
Topic ClosedBypass valves after winterizing
shavano70 View Drop Down
Direct Link To This Post Topic: Bypass valves after winterizing
    Posted: 22 Apr 2014 at 10:59am
Last year we took our R-Pod to be winterized by a professional. I wanted to de-winterize it myself, but I am confused by what I found: the valves going in and out of the heater are open, and the bypass is closed. Shouldn't they be opposite? Should I be concerned? Any advice would be appreciated.
Direct Link To This Post Posted: 22 Apr 2014 at 2:33pm
Make sure you are interpreting "open" and "closed" correctly.  The hot & cold valve handles should be perpendicular to the pex, and the bypass valve parallel, for winterization.  Then in the summer the hot & cold will be parallel, and the bypass perpendicular.
If they are in fact in the summer position the person that did the work either completely filled the water heater with antifreeze (a waste of antifreeze but otherwise not a problem), or did the winterization and then changed the handles back so they would be in the correct position for you come spring time (also not a problem).
Direct Link To This Post Posted: 22 Apr 2014 at 4:59pm
That was nice of them!
Direct Link To This Post Posted: 22 Apr 2014 at 5:02pm
There is a possibility they winterized with air, in which case they may not have turned the valves. I don't.
Direct Link To This Post Posted: 22 Apr 2014 at 6:12pm
Also a possibility!
