List Your Mods: |
Page <1 5556575859 78> |
SuJoPodders ![]() Newbie ![]() Joined: 02 Jun 2013 Location: Janesville Ca. Online Status: Offline Posts: 16 |
![]() ![]() ![]() ![]() Posted: 15 May 2014 at 3:12pm |
Thanks Cody91!
The shelving came from Lowes. It's called Roth + Allen. It comes in 72" length which is just about two inches short of the distance from each side wall. I used four 3" steel corner braces to attach to the side walls. I first removed the valance and mini blinds and using Molly bolts attached them to the walls. I mounted it just above the lights and have experienced no headbanging even at my 6'4" height. Have ordered a 2 1/2" galley rail (like the one above the refrigerator) to attach to help keep loose items from falling off. The rear shelf is the same closet shelf cut in half and attached the same way.
Nice write-up.
cody91 ![]() Senior Member ![]() ![]() Joined: 12 Feb 2014 Online Status: Offline Posts: 184 |
That's really cool. Where did you get the shelf over the dining area and what did you use to secure it?
One of the first things we noticed about our 177 was the lack of storage space
![]() ![]() ![]() Added a couple of space saving items. ![]() ![]() Installed a mirror on the bathroom door. ![]() A stove cover/cutting board ![]() A few needed bathroom bathroom accessories. ![]() Replaced the light bulbs with battery saving LEDs ![]() ![]() ![]() And a personalized license plate of course!
ilthyn ![]() Groupie ![]() ![]() Joined: 21 May 2013 Location: Alberta Online Status: Offline Posts: 66 |
Thanks, LePodders, Arnie the Podinator will be smiley.
ilthyn
LePodders ![]() Groupie ![]() ![]() Joined: 20 Nov 2013 Location: Louisiana Online Status: Offline Posts: 80 |
When folded down, the measurement is 2 inches.
Poddy by Nature |
A question on your table mod:
Can you tell me, please, when the table is folded down, what is the horizontal measurement from the wall to the table top surface? I am asking because we load my wife's (heavy) electric bike in the table area and the dimensions are tight. If the table sticks out too far then we cannot copy your excellent example. FYI, the bike rear wheel is secured in a channel mounted on a plywood sheet and then the bike is secured with tie-downs from under the seats. Inverted, the plywood base then becomes an outside table, mounted atop the wheel mudguard. A step stool is used for legs. Thanks, ilthyn
We can still use the dinette as a bed. If we plan on having company We have a thick piece of plywood that will extend across both seats with table folded down. It would only be kids using it
Poddy by Nature |
Scoul ![]() Newbie ![]() ![]() Joined: 28 Jan 2014 Online Status: Offline Posts: 27 |
Added a fantastic vent ultra breeze cover with bug screen. Now the vent can stay open in foul weather. I might add that the people at the manufacturer are the best, as I needed a replacement part!!!
"Anyone can hold the helm when the sea is calm." Publilius Syrus
2015 GMC 1500 2014 182g 2009 Harley FXSTB |
Cap-n-Cray ![]() Senior Member ![]() ![]() Joined: 22 Feb 2014 Location: Bainbridge Is Online Status: Offline Posts: 121 |
Keenan,
You are not going to use the dinette as a bed? |
Cary
2014 RP-177 |
