  New Posts New Posts RSS Feed: Dead furnace
Topic ClosedDead furnace
CharlieM View Drop Down
Direct Link To This Post Topic: Dead furnace
    Posted: 12 Feb 2014 at 11:06am
I am a bit disadvantaged since I am out camping, but  I believe Rh means Red Heat and is +12Volts.White is usually the heater. Green is the heater blower if it has a separate fan control, but POD heaters do not use this function. The heater itself controls the blower. Shorting the green to white may give a false indication of non operation. Normally I would suggest shorting the red to white, expecting to blower to begin its cycle, but then I would remember the FR motto: Let no two Pods be the same. You could check the red wire with a voltmeter to see if is +12V. If it is, try shorting to the white. If the red really measures 7.5V it is some kind of internal logic supply and much more research is required.
Replacing the Duo-Therm may be a challenge if you want to retain the two speed A/C fan function. Most house thermostats just have fan on/auto.
Tars Tarkas View Drop Down
Online Status: Online
Direct Link To This Post Posted: 15 Feb 2014 at 11:44am
Well, the thermostat works for every thing but the furnace.  I've tried shorting it every way that makes any sense at all.  The furnace wire to the thermostat ground wire does make a barely audible muffled little click at the furnace, but still no heat or furnace fan.
Any other thoughts?  Does it seem prudent to replace the thermostat still?
Direct Link To This Post Posted: 15 Feb 2014 at 12:43pm
 Have you checked all of the fuses to make sure the one for the furnace isn't blown?  I also just read there is likely a circuit breaker either under the front cover of the furnace or behind the furnace (don't know why it would be back there).
Direct Link To This Post Posted: 15 Feb 2014 at 1:28pm
The only fuse I know about is the 7.5 amp fuse in the main fuse panel and it's fine.  All the fuses there are fine.  I have the cover off the furnace, and don't see another fuse.  There is a black button thing that I think is hooked straight to the thermocouple.  It's pushable but doesn't do anything for me.  There is a circuit board at the furnace, mounted sideways, at right angles to the front of the furnace.  I can see an off/on switch on there that is on, but without pulling the furnace, I don't see how to access the circuit board.  That would mean disconnecting the LP copper pipe, which seems like a last resort to me.  And the furnace definitely won't work with no LP, so other than something very obvious like a blown fuse, there's not a lot of point in my pulling the furnace out.
If we know there is a fuse there it might be worth it.  I'll see what the manual for the furnace says about that.  The manual has not been much help so far though.
Direct Link To This Post Posted: 15 Feb 2014 at 2:16pm
The furnace itself works!  I was able to jump across the relevant connections at the furnace.  With the top off of the bench above the furnace it is easy to see where the red and white thermostat wires connect to two light blue wires, one of which has a tape label marked ++++++.  This is outside the furnace but under the seat box.  The +++++ wire is indeed hot.  When I connected those two light blue wires the furnace fan started instantly and the gas lit up in just a few seconds.  Disconnecting that jumper caused the flame to go out.  The fan ran for about a minute and quit, just as it should.
So, early advice/speculation was right on target.  I'm totally satisfied now that the problem is in the thermostat or the wires between the thermostat and the furnace, and not with the furnace itself.  I'm a little bothered still about the fact that nothing I could short across at the thermostat caused the furnace to start, so I don't know how the wires would have been damaged, but this seems to point to a wiring issue.  They are skinny little wires and with the vibrations of normal travel something could have happened.  I should be able to check the wires easily enough with an ohm meter though.
I'll follow up and let you know how this finally resolves itself, but thanks for the help so far!  I know what to do now....
Direct Link To This Post Posted: 15 Feb 2014 at 4:48pm
Yup, if jumping those same 2 wires at the thermostat didn't work I agree it is a wiring issue.  If you can't easily run new wires to the original thermostat you could mount a dedicated thermostat near the furnace.  Just not too close or it will cycle on/off too often and leave the rest of the camper too cold.
Boomertype View Drop Down
Direct Link To This Post Posted: 15 Feb 2014 at 9:21pm
Maybe I missed it but did you use a multimeter to check continuty for all the connections to the heater?
I never leave home without one.
Direct Link To This Post Posted: 22 Feb 2014 at 11:33pm
The furnace is up and running again.  It was a broken thermostat wire.  I determined that there was no continuity in the red thermostat wire so I started at the furnace end and pulled a new pair of wires through with the old wire roughly to the thermostat.
This is where it gets kind of interesting.  The thermostat wires from the furnace do not go to the thermostat.  No, they go to the air conditioner.  It's a red and white pair that goes from the furnace to the air conditioner, then a 6-wire thermostat cable goes from the air con to the thermostat.  You can't check the continuity from the furnace to the thermostat.  You can check it from the furnace to the air con and from the air con to the thermostat.  The long run with the most bends is the one from the furnace to the air con, so that's what I checked first.
For the most part, pulling the wire pair along the existing chase was fairly routine.  The cable anchor straps, mostly where the wires turn, were the trouble spots.  All of them were doable though, except the one above the ceiling and the lower portion of the air conditioner, where the wire goes from the air conditioner, above the ceiling, over a little then down between the shower stall and the wall outside the shower.  I could sort of pull the wire down a little way, so that the end would move up out of the air conditioner, but it would not move at all if I tried to pull it up from the floor, over the ceiling and down into the air conditioner.  That's why I pulled from the furnace to about the thermostat.  I spliced the new wire to the old wire more or less behind the thermostat.
I had to loosen the paneling on the wall with the thermostat to make any of this work.  Actually, in hindsight, I guess I could have spliced under the shower if I'd known in advance where the break in the wire was.
I did find the wire break.  As of now I don't know where it was in the run of wire.  I'll see if I can get a good idea when I do the rest of my cleanup tomorrow and put away my tools.  It shouldn't be too hard to get a good idea by laying the old wire out along its old path.
I was surprised that the thermostat was not directly connected to the furnace.  There's bound to be a good reason, but I have no idea what it is.  I think you could run a two-wire, dedicated thermostat to the furnace, and that would have been marginally easier, but then I would have had two thermostats (and would have been able to run the air con and the furnace at the same time).
None of this overall task was particularly difficult but it would have been much more straight forward if Forest River provided some schematics and better manuals.  After carefully reading the manual for the "air handler", I discovered the thing about the furnace wires going to the air conditioner, but I still had no clue whether they went to the inside portion of the air conditioner or the part up on the roof.  I took the cover off the roof portion looking for wires that weren't there and I still have to get up there tomorrow to put the cover back on.  Thankfully there is no rain in the forecast.
Goose View Drop Down
Direct Link To This Post Posted: 22 Feb 2014 at 11:51pm
Sounds like a lot of work, glad that you were able to make the repairs and get the furnace to work as intended. Goose
yellowstonestu View Drop Down
Direct Link To This Post Posted: 23 Feb 2014 at 6:41pm
I had a hauntingly similar issue last summer with my 173. I had the thermostat replaced, it worked once, then same issue all over again. I took it to my local RV repair place, they couldn't find anything wrong, so finally took the inside cover off the ac unit and found two a loose wire nut there that came from the thermostat. Problem solved?? It worked when I put it away for the cold Colorado winter. Will know more in April when I take it out of winter storage.
Yellowstonestu & Bela the Vizsla
2008 Toyota FJ
2015 RPod 179 (Pod #2)
