Page 12> |
Craneman ![]() Senior Member ![]() Joined: 12 May 2013 Location: Tokeland,wa Online Status: Offline Posts: 387 |
![]() Posted: 03 Feb 2014 at 1:40pm |
Don`t know if this is any help but this is whay I came up with
Jo and Gary 2010 174 2011 Ford 150 |
The non-slide models have a single sewer outlet. If you mount a tube sideways on the rail, you should drill several small holes on the bottom of the tube for drainage. Usually they come with holes but expect the mounting brakets to be "up". I only had 2 pics in my post showing the tube, the 2nd one shows it installed but it is rather dark so it may not be obvious at first glance. |
wingnut2312 ![]() Senior Member ![]() ![]() Joined: 25 Aug 2013 Location: MI Online Status: Offline Posts: 231 |
Ok. I wanted to mount mine as you did, but didn't think of the weather stripping. Thanks!
2014 rpod 182G
Ford Expedition |
chiman ![]() Groupie ![]() ![]() Joined: 03 Dec 2013 Location: Oregon Online Status: Offline Posts: 44 |
Sorry but don't have a camera so no pictures. I think that all the posts on this subject have some pics attached. Maybe only difference is most put the 60 inch tube cross ways on their pods which worked well for them. For me, on my pod is was better to mount it to the side of the frame as I described in my post. Only thing I didn't say is that prior to tightening down the mounting screws I glued a strip of foam weather striping along the side of the tube that would be up against the frame. I did this to give some cushion from the tube to the frame. It was just one inch wide by half inch foam weather stripping which I got at Lowes.
All in all it made a nice installation and looks nice. Rphelps |
2017 180 "Frog" towed by 2017 Toyota Tacoma with co-pilot "Willow" a 80 lb Labradoodle
Clicked on it, but it just shows the tubes on the ground. I was looking for pics of chiman's install.We are also looking to upgrade our tube also. The little five footer sewer hose wotks ok, but we want the 15' Rhino.
2014 rpod 182G
Ford Expedition |
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Online Posts: 1454 |
Click on the link in Techntrek's post. There's no need to repost the pictures if they are already on the forum. TT |
FJ Cruiser |
Pictures?
2014 rpod 182G
Ford Expedition |
Thanks for the pictures Doug. It looks like you ran the grey water to the black outlet for one dump, or did your pod come that way? That's something I'd like to get around to.
Still amazed at the before and after of your roof! TT |
FJ Cruiser |
dsmiths ![]() Senior Member ![]() ![]() Joined: 10 Oct 2011 Location: Southern Ind Online Status: Offline Posts: 866 |
I did the same, I searched the name of the factory storage tube and was surprised that it was less than 35 bucks, slight modification and home made brackets mounted it perfectly.
Dane and Donna Smith
TT - the first 2 pics in this thread show some of my installation. http://www.rpod-owners.com/forum_posts.asp?TID=3588 |
Page 12> |
