London
Topic: dometic thermostat wiring Posted: 09 Dec 2013 at 12:53am |
Hey friends! I pulled off the thermostat and I didn't make note of which color wires go where.. Thought I'd remember but got sidetracked. Not sure what the colors are! Can anyone help me out real fast? Thanks
Posted: 09 Dec 2013 at 8:23am |
Which thermostat do you have?
London
Posted: 09 Dec 2013 at 10:57am |
This little guy here...
http://www.dyersonline.com/dometic-single-zone-cool-furnace-lcd-thermostat.html?utm_medium=shoppingengine&utm_source=googlebase&gclid=COne4d_Ao7sCFUSSfgodU18APg
Posted: 09 Dec 2013 at 2:08pm |
OK, that's the digital one, some are analog, like mine. Hopefully someone will pull theirs off and snap a quick phone pic or something to help you out.
Bill-GA
Posted: 09 Dec 2013 at 6:33pm |
Pix of thermostat - hope this helps ....
Bill & Bev
13 yr old dachshund 'Elsa'
2011 Toyota Tundra 2WD TV
London
Posted: 09 Dec 2013 at 7:40pm |
Thanks Bill - I did see that picture but it's not the same as mine :( there is a couple extra wires and the colors don't exactly match up. Mine are red white and blue!
I do think I found a pic on FR website, which hopefully will work. From what I gather color schemes may not be consistent and I may just have to find them at the AC unit hookup to see what they are wired to at that end.
Posted: 09 Dec 2013 at 8:07pm |
Always a good idea to look at the other end and not trust Bob at the factory to have bothered with following a set plan..
With the advent of the camera phone, I take reference pictures all the time..
jj
Posted: 09 Dec 2013 at 8:31pm |
The following are the wire colors used in a 5 wire thermostat cable. if it is hooked up correctly by installer. - G – Fan, usually a green wire
- R – 12 Volt usually a red wire
- C – 12 Volt Common usually a blue wire
- Y – Cool, usually a yellow wire
- W – Heat, usually a white wire
GaRedneck81
Posted: 09 Dec 2013 at 9:14pm |
Exactly correct !
GaRedneck81
USN Retired
RP-172
London
Posted: 10 Dec 2013 at 7:48pm |
Got it hooked back up! Thanks for everyone's help
