dometic thermostat wiring
URL: http://www.rpod-owners.com/forum_posts.asp?TID=4253
Printed Date: 18 Aug 2025 at 7:18pm
Topic: dometic thermostat wiring
Posted By: London
Subject: dometic thermostat wiring
Date Posted: 09 Dec 2013 at 12:53am
Hey friends! I pulled off the thermostat and I didn't make note of which color wires go where.. Thought I'd remember but got sidetracked.   Not sure what the colors are! Can anyone help me out real fast? Thanks
Posted By: furpod
Date Posted: 09 Dec 2013 at 8:23am
Which thermostat do you have?
Posted By: London
Date Posted: 09 Dec 2013 at 10:57am
This little guy here...
http://www.dyersonline.com/dometic-single-zone-cool-furnace-lcd-thermostat.html?utm_medium=shoppingengine&utm_source=googlebase&gclid=COne4d_Ao7sCFUSSfgodU18APg
Posted By: furpod
Date Posted: 09 Dec 2013 at 2:08pm
OK, that's the digital one, some are analog, like mine. Hopefully someone will pull theirs off and snap a quick phone pic or something to help you out.
Posted By: Bill-GA
Date Posted: 09 Dec 2013 at 6:33pm
Pix of thermostat - hope this helps ....
Bill & Bev
13 yr old dachshund 'Elsa'
2011 Toyota Tundra 2WD TV
Posted By: London
Date Posted: 09 Dec 2013 at 7:40pm
Thanks Bill - I did see that picture but it's not the same as mine :(
there is a couple extra wires and the colors don't exactly match up.
Mine are red white and blue!
I do think I found a pic on FR website, which hopefully will work. From what I gather color schemes may not be consistent and I may just have to find them at the AC unit hookup to see what they are wired to at that end.
Posted By: furpod
Date Posted: 09 Dec 2013 at 8:07pm
Always a good idea to look at the other end and not trust Bob at the factory to have bothered with following a set plan..
With the advent of the camera phone, I take reference pictures all the time..
Posted By: jj
Date Posted: 09 Dec 2013 at 8:31pm
The following are the wire colors used in a 5 wire thermostat cable. if it is hooked up correctly by installer.
  • G – Fan, usually a green wire
  • R – 12 Volt usually a red wire
  • C – 12 Volt Common usually a blue wire
  • Y – Cool, usually a yellow wire
  • W – Heat, usually a white wire
Posted By: GaRedneck81
Date Posted: 09 Dec 2013 at 9:14pm
Exactly correct !
GaRedneck81
USN Retired
RP-172
Posted By: London
Date Posted: 10 Dec 2013 at 7:48pm
Got it hooked back up! Thanks for everyone's help
