  New Posts New Posts RSS Feed: Leveling iwth Stabilizers
Topic ClosedLeveling iwth Stabilizers
strorg View Drop Down
Direct Link To This Post Topic: Leveling iwth Stabilizers
    Posted: 27 Nov 2013 at 1:23pm
I understand the the pod should be leveled primarily using pads or blocks under the wheels and the tongue jack.  How much can the stabilizing jacks be used to fine-tune the leveling?  I'm not suggesting taking all the load off the wheels, but it seems that the jacks will need to carry some load to get proper side-to-side leveling.
Thanks...Tom
Tom and Tracy
Mobile, AL
2014 RP-178
Outbound View Drop Down
Direct Link To This Post Posted: 27 Nov 2013 at 2:57pm
None at all.
Stabilizers are for stabilizing.  As in lower them to the ground.  They are not there to bear weight of the trailer.  Snug them up just enough to keep the trailer from jiggling about as someone walks around inside.
If you'd like to infinitely fine-tune your side-to-side leveling, a Bal Leveler would likely be best.
Direct Link To This Post Posted: 27 Nov 2013 at 3:50pm
Thanks Craig - that looks like a good solution.
Tom and Tracy
Mobile, AL
2014 RP-178
Direct Link To This Post Posted: 27 Nov 2013 at 5:37pm
Yup - make contact and then 1 more turn max.
