  New Posts New Posts RSS Feed: Propane duration
Topic ClosedPropane duration - Event Date: 15 Nov 2013 - 30 Nov 2013
Lefty View Drop Down
Direct Link To This Post Calendar Event: Propane duration
    Posted: 15 Nov 2013 at 10:06am
I'm going to the Smokies next week in the pod for three nights. I'm curious how long a new tank of propane will last just using the furnace at night for about 8 hours per night and the fridge the whole time. There will be no shore power.
Thinker View Drop Down
Direct Link To This Post Posted: 15 Nov 2013 at 10:32am
How cold will it be next week? What temperature do you consider comfortable in the pod. Those questions are rhetorical... just illustrating that without full data, it is impossible to predict propane usage.
However, that being said. Your primary concern will most likely be the battery. I don't know if you can make it more than one night on the battery.   Or do you have two?
But, I could be wrong depending on the cycling of the furnace based on the temperature variables.
Direct Link To This Post Posted: 15 Nov 2013 at 11:02am
I have a 2 battery setup. Temps will be in mid to low 20's.
sandlapper View Drop Down
Direct Link To This Post Posted: 15 Nov 2013 at 11:13am
The propane itself if you have a full tank should not be a problem. The real problem comes with how long the battery will last and that depends on your thermostat setting and the outside temperature. I think two days at the most unless the temperatures is really mild and you don't use much 12 volts to run lights etc. But I would plan on it lasting one day only. Incidentally I never use the furnace much during the day.
I have stayed a the smokies  and on the parkway for a week and more in my RV and just cranked the engine up about half hour or so a day to recharge the battery and never had any problems but you will really need to conserve the electricity usages.  To avoid using my lights I used l led lights with it on batteries to power them. I also used a voltage meter to monitor my battery status so I would not run the batteries completely down before recharging them with my engine.Embarrassed
sandlapper
StarPod
Direct Link To This Post Posted: 15 Nov 2013 at 11:17am
Thanks for the reply. Only going to use the furnace at night for about 8 hours set on 60 degrees. Will not be using lights at all.
Direct Link To This Post Posted: 15 Nov 2013 at 11:25am
Change your interior lights to LED bulbs. This makes a HUGE difference.
Direct Link To This Post Posted: 15 Nov 2013 at 11:28am
With temps in the low 20's you will have a catch 22. With no or little heat, your water tank will freeze. You will be ok if you fully winterize and only use gallon jugs of drinking water.
If you do run the heat, you will need a small generator to charge your batteries.
Direct Link To This Post Posted: 15 Nov 2013 at 12:53pm
Those temps will reduce your effective battery capacity by 10-15%.  By the time you get to -22 F you loose 50%, temporarily.  This may mean a daily charge is necessary.  If you do use your TV to top-off, hook it up using jumper cables and as someone said, run the engine for 30 minutes.  During the summer I only recommend doing this every other day.
Direct Link To This Post Posted: 15 Nov 2013 at 3:13pm
   Living in south Florida we never used the propane very much. We have never refilled it, we still have propane in our tank from when we bought our r-pod in April of 2009. We mostly used 12 volts for the refrigerator and had 110 volts at the camp site and used the microwave for cooking or electric hot plate outside.      David
2014 Ram 1500 Quad cab
rpodcamper.com View Drop Down
Direct Link To This Post Posted: 15 Nov 2013 at 3:59pm
Having dry camped in pa during the winter - 2 Battiries will not last 3 nights without charging them someway.  What I do for a 2 night weekend is make sure the camper is winterirized and carry Gallons of water with me in the camper.  I will run the heater first thing in the morning as I'm getting up and getting ready for the day and also at  night while getting into bed and then turn it as low as it will go during the night.  I sleep in a zero degree bag so I'm nice and warm.  by the end of the second night the batteries are normally empty.   If I need to charge I use jumper cables and my truck running for a while.
