kymooses
Topic: TV brake controller compatibility Posted: 16 Oct 2013 at 1:27pm |
Originally posted by Sleepless
Most state laws require operational brakes on trailers over 1500 pounds. He is right about the truck being able to pull the trailer without a controller, but he is absolutely wrong about not needing the controller. Insist on swapping the controller to the Silverado.
Now for a disclaimer. Does the Silverado towing package include a brake controller? I am assuming that it does not.
Bob
Yes don't let your dealer con you.
Bob is 100% right.
TrinityTurret
Posted: 16 Oct 2013 at 1:35pm |
There's only one way...
Posted: 16 Oct 2013 at 7:40pm |
Originally posted by TrinityTurret
Thanks Bob. The truck comes with wiring, but not a built-in controller. Ours is a Tekonsha Primus IQ 90160.
You will want to keep that brake controller. With the built-in wiring on the Silverado it is an easy job to move it over. Chevy used to have a plug under the dash which made the job very easy but when they introduced their own built-in brake controller (an option) they started giving you the bare wires (around 2005 I believe). Still makes the job easier than it used to be when you had to wire everything yourself.
SNO4ME
Posted: 16 Oct 2013 at 8:14pm |
Here in Wisconsin we are required to have brakes with a 3000 lb rated Gross trailer weight which would of course include R Pods. I would really question the credibility of a salesman that told me something like that. Maybe, possibley it would be legal in your state but I would not go without the brake controller. Also in my understanding if you have a towing package it should just plug in under the dash.
Bruce & Donna in the Sno Pod
(and Brewer too)
2011 RP 177
Posted: 16 Oct 2013 at 8:20pm |
I think I would go to a different dealer also. That's bad advice to go without trailer brakes.
You might want to consider a truck equipped with a controller from the factory. My F150 has a factory controller and it works extremely well. I am sure the other brands do also.
2011 R-Pod 177
2010 Ford F-150
Posted: 16 Oct 2013 at 9:44pm |
See my post above.
TrinityTurret
Posted: 16 Oct 2013 at 11:00pm |
We got the Silverado...and it comes with "HD (heavy duty) towing package" (all the specs say it can tow 7,200 pounds---so now we can breathe a sigh of relief after putting the 'bed-in-a-box mattress in the pod, LOL)...dealer will put our brake controller on it :)
Posted: 17 Oct 2013 at 2:34pm |
Good to hear they'll move the brake controller for you. I hope they aren't charging you, it is literally a 15 minute job.
coopercdrkey
Posted: 17 Oct 2013 at 4:55pm |
Good to hear they'll move the brake controller for you. I hope they aren't charging you, it is literally a 15 minute job. |
Well, it took me about half an hour, but truly is a 15 minute job!
Bob and Joyce
RP 177 "Key Pod"
