creating an instruction & maintenance manual |
Page <1 89101112 25> |
![]() ![]() ![]() ![]() Posted: 29 Sep 2013 at 2:24pm |
My socket is a pretty conventional socket that does need an adapter.
Broz ![]() Newbie ![]() Joined: 21 Sep 2013 Location: Belleville IL Online Status: Offline Posts: 16 |
Question : We are just getting started and could not get the Gas knobs on the stove to go to the light position - It there a trick.
Bob Rosner |
Broz form IL
SNO4ME ![]() Senior Member ![]() Joined: 28 Sep 2013 Location: NW Wis Online Status: Offline Posts: 122 |
I'm assuming a little bit here because we are newbies this fall ourselves. I believe the stove top does not have an integral ignite r. Or ours doesn't work, we have a 2011 - 177. |
Bruce & Donna in the Sno Pod
(and Brewer too) 2011 RP 177 |
SchipperPod ![]() Groupie ![]() ![]() Joined: 06 Sep 2013 Location: Utah Online Status: Offline Posts: 81 |
We have a 2014 178, and you need to light the stove with a long match or gas lighter. I think turning the dial to Light just means it's the maximum amount of gas to catch from your flame. It doesn't have a self-spark system to light it.
Happy tails and trails!
Teri & Jeff Black Plus 4 Schipperkes: Kodi, Jessie, Maggie & Bear 2014 R-Pod 178 2013 Santa Fe Sport Turbo |
SEE??!! you are sharing the knowledge already!! "Good on you", as they say. No electric lighting action, turn to the "light" area nad light with a long/BBQ lighter.. |
wagnert ![]() Newbie ![]() Joined: 09 Jan 2012 Location: Gig Harbor, WA Online Status: Offline Posts: 21 |
Wow! Your dealer gets an D-.
Ours explained details like stove lighting and provided a lighter in the drawer under the stove. |
Tom Wagner
2012 R-Pod 177 2003 Toyota Sienna |
I moved G-Force's post to its own thread here: http://www.rpod-owners.com/forum_posts.asp?TID=4116
Followed the Winterization instructions Wow - OK I an a NEWBEE and it was great to have the fantastic instructions. At least R-Pod marks on the side of the trailer the location of the Drain Plugs.
Thank you again for the great instructions - It only took 1.5 hours and included reading the instructions several times.. ![]() |
Broz form IL
Huh, sounds like my afternoon. ![]() From another newbie, thanks again. I talked to a couple other RVers that I know and they both said "what low point drain?" |
k4fcp ![]() Newbie ![]() ![]() Joined: 16 Jan 2013 Location: Blacksburg, VA Online Status: Offline Posts: 25 |
Great idea on the IM. The hot water tank appears to have two drains underneath and I'm assuming the one towards the rear is the drain. I unscrewed that (rear cap) but water just trickles out and I think the little white gasket (like the one for fresh water) is stuck in the hole. Best way to remove?
Muchas Gracias! |
Rich
2013 R-177 2013 Ford F 150 4X4 (yeah, bought a new truck)! |
