Topic: towing vehicles? Posted: 06 Oct 2013 at 1:36pm |
Good question. I will have to ask him next time I am at his shop,
2011 R-Pod 177
2010 Ford F-150
CharlieM
Posted: 06 Oct 2013 at 9:23am |
For what it's worth, I just went through that drill on my Honda Pilot at 35k. Honda recommmens changing transmission oil at 30k. The dealer just does a simple drain and refill the first time at 30k and a complete flush the next time. And, comntrary to what I had been reading, the Honda has no filter. If your Toyota has one my guess is you'd replace it every other fluid change. Only my guess.
hogone
Posted: 06 Oct 2013 at 9:14am |
thanks for the info, and just to confirm, no new filter correct? how many miles on your first change? hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Posted: 06 Oct 2013 at 8:44am |
The mechanic I use has a machine that hooks in line with the cooler lines and he tells me that it allows him to remove the fluid from the converter as well as the transmission, flush the system then replace fluid along with some additives. He has taken care of my vehicles for some years successfully, so that is the route I will use. YMMV
2011 R-Pod 177
2010 Ford F-150
hogone
Posted: 06 Oct 2013 at 8:15am |
My F150 has 35,000 miles. Was considering changing the tranny fluid. Would it be unwise to just drain the fluid, add drain amount (new fluid) back in and not replace the filter? hogone
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
arkieguy
Posted: 05 Oct 2013 at 8:33am |
We tow our pod with a Toyota Tacoma dbl cab with tow package. On our most recent trip we got 14 mpg with pod (182g) , all our stuff and two kayaks on top. We towed through the ouachita mountains with no struggles. Great option if you don't want a full size truck.
Camper Bob
Posted: 04 Oct 2013 at 9:43pm |
Your are correct on maintenance that will futher the life of the vehicle. However, my concern is having enough residual value to make a decent dent on a new purchase. Not sure that either avenue is correct. Each has to examine our resources and decide what makes the most sense. Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
dsmiths
Posted: 04 Oct 2013 at 9:02pm |
Techntrek, thanks for your level head. keep up the good advice. as the drama wears on there are a host of things one can do. If you like your t.v. and its getting some miles on the clock, think about doing some repair/replacements a little at a time. Research your t.v.'s weak points. change the fuel filter every 30k miles. service the cooling system every 50k miles. I service my transmission every 50k miles. I am approaching 100k miles and am going to do the following. at 100k the recommended maint by g.m. spark plug replacement, service both front and rear differentials, service the transmission and transfer case and change the coolant. at 125k I am going to replace the alternator and serpentine belt tensioner. at 150 k the fuel pump and starter. I should make a good run into 200k miles and by that time I will be looking for a change. I own an A.C. Delco Tech shop so I have a slight edge on costs. but I figure the things I have planned will be about 4 car payments. g.m. has a good record on transmissions holding up. Cross your fingers and go for it.
Dane and Donna Smith
2011 RP-172
lift kit
Craneman
Posted: 03 Oct 2013 at 11:41pm |
My Chevy 1500 with v/6 auto is better, drove 296 miles today to get the lighting recall taken care of and I got a WHOOPING 8.7 mpg. Mostly keeping up with freeway speeds
Moe
Jo and Gary
2010 174
2011 Ford 150
Posted: 03 Oct 2013 at 9:06pm |
Originally posted by wallawallaron
I think you are way over sensitive. Its O.K. to complain about something that happened over 30 yrs ago but to state my view and state another example which was just as lame doesn't sit well with your sensitive soul. Sorry about that I guess you won't have to listen to my view anymore . This form has become way to sensitive for me. Read his post over he is the one complaining about something that happened 30years ago. So long happy poding. P. S. Your view of a insult is you opinion,none was felt on this end. |
Saying his opinion is lame just because it doesn't agree with yours is childish. Opinions differ - look at Washington right now, I'm currently unemployed because of their differing opinions - that doesn't mean you can call names and claim yours is better.
