  New Posts New Posts RSS Feed: Sylvania convection microwave
Topic ClosedSylvania convection microwave
skyguy View Drop Down
Direct Link To This Post Topic: Sylvania convection microwave
    Posted: 28 Sep 2013 at 9:54am
Hi Guys... I recently purchased a used 2009 173 and enjoy it. Everything works but the Sylvania convection/microwave oven, it pops and sparks. I replaced the mica shield but it still doesn't work. Two questions... Has anyone else had problems with the Sylvania microwave? It seems to be discontinued online. Secondly, if I were to replace it, does anyone have a recommendation for an oven (and frame) that will fit the opening?
Thanks!
21grandma View Drop Down
Direct Link To This Post Posted: 28 Sep 2013 at 2:21pm
Thanks!
Our used 2012 177 did not have unit installed. We purchased a Dometic convection microwave that came with the frame at campersworld. Fits perfectly: looks factory installed.
21grandma
Direct Link To This Post Posted: 28 Sep 2013 at 9:22pm
Welcome.
Direct Link To This Post Posted: 29 Sep 2013 at 7:54pm
We have a 2010 171 with the Sunbeam microwave it it and it works great. What amp are you plugging into ? We were told when we bought ours,to only use 30 amp service. If you try it on 20 amp it will supposedly malfunction and could melt the plug adapters together. Not sure if that is true.
Direct Link To This Post Posted: 29 Sep 2013 at 8:35pm
Hmmm... Thanks! Well, I was testing the whole unit back home, plugged into my home power. I'll have to measure the opening to see if the Sunbeam would fit...
Direct Link To This Post Posted: 29 Sep 2013 at 9:18pm
15 or 20 amp service is fine, just make sure to ONLY run one of the big things at a time - A/C, microwave, electric element in the water heater.  Any one of them will be fine.  If you do have 30 amp service only run 2 of those 3 at a time.
Direct Link To This Post Posted: 30 Sep 2013 at 7:01am
  We have the Sylvania microwave in our 2009 and have never had a problem with it. We have used it every time we have been camping. Sorry that yours does not work hopefully ours continues to work with out a problem. I think your right they have been discontinued for some reason. Perhaps a Sunbeam would be a good replacement. Welcome to the forum!  David and Danette
2014 Ram 1500 Quad cab
P&M View Drop Down
Direct Link To This Post Posted: 30 Sep 2013 at 7:51am
make sure that you were not using the raised metal plate inside of it while operating on microwave only ... only use the metal plate when operating on convection or combo.
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
Direct Link To This Post Posted: 30 Sep 2013 at 12:58pm
Thanks for all the responses. I took the unit out and tried it in my kitchen. The magnatron seems to be toast. I'll replace it. I may try the Sunbeam if it fits... Other suggestions welcomed.
Smile
