New Owner Needs Help With E2 hitch. |
HuronSailor
Topic: New Owner Needs Help With E2 hitch. Posted: 24 Jun 2013 at 4:53pm |
You'll like the risers. I went for a couple of years before I added mine but glad I eventually did. No more scraping the tongue jack at gas stations.
Posted: 24 Jun 2013 at 4:25pm |
Ah, now I see. Made your link clickable, I hope you don't have a problem ordering the risers.
pkelly251
Newbie Joined: 21 Jun 2013 Location: Shoreview, MN Online Status: Offline Posts: 5 |
Posted: 24 Jun 2013 at 2:51pm |
Thanks for the replys. I am trying to place an order for the riser kit. It sounds like that should help. Techntrek - Here is a link to what my dual propane tank holder looks like with all the parts. With the different comment about the Rpod being lite on the tongue, I am hopeful it can handle it.
Pat
Rpod 177 & and Jeep Liberty |
pkelly251
Posted: 24 Jun 2013 at 2:42pm |
Pat
Posted: 24 Jun 2013 at 9:40am |
Off-topic, is that a dual-propane-tank platform just behind your jack? How do the tanks attach to that pole?
Posted: 24 Jun 2013 at 9:38am |
As already mentioned, first get the risers and then go from there. You'll gain 3 1/2 inches from the risers so you won't need a much larger shank. Use this online tool to figure out the shank size you need (the Equalizer is the E2's big brother and is made by the same company), just add 3 1/2 inches to the Coupler Height. Until you get your final configuration, if the 173 has the fresh water tank up front I recommend towing with a full tank to put more load on the tongue (or filling either the gray or black tank if they are up front and you can dump them when you get to camp).
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1216 |
Posted: 24 Jun 2013 at 9:36am |
We have the Equalizer 4 point sway control, do not know how that differs from the E2 that you have as far as shanks and there clearance. We had the factory tow package that included the hitch. The shank we used was part#90-02-4340 with a 6" drop and 10" rise, shank length 12". We no longer have the Liberty and now have a 2012 Ram 1500 and with that we use the same Equalizer hitch and shank. Hope this helps. David
Seanl
Senior Member Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
Posted: 24 Jun 2013 at 8:50am |
Here is my E2 Hitch on my 09 Jeep Liberty. I have the 2 1/2 inch drop and axle risers. I am still about an inch high but I have not had any issues with this. I would recommend axle risers as they make sense anyways. I scraped both rear jacks off of my Pod before I put the risers on. You will probably have to go to the the 4 inch because It looks like you have a stock hitch which mounts behind the bumper . Mine is a Curt hitch that hangs below the bumper a good 2 inches. I hope this helps some. |
David and Danette
Posted: 24 Jun 2013 at 5:43am |
Welcome to the forum! Our last tow vehicle was a 2010 Liberty and we used the Equalizer 4 point sway control WDH. The Liberty has a high receiver and we too had to order the optional longer shank. I forget the length I will have to measure it not able to do that now. A question do you have the risers on you Rpod? If not I would highly recommend them it will give you more clearance all the way around for your hitch and trailer. Later today I can give you the measurements of our shank. We did get the risers and found out before the risers we did not have enough clearance for the hitch. The Equalizer hitch is a great hitch and helps a lot in towing especially with the Liberty and its short wheel base. Let me know if I can be of any more help. David
pkelly251
Posted: 23 Jun 2013 at 11:15pm |
Hi all, I have been gaining alot of good information from all of you on the forum over the last several months. I decided on a model 177 and picked it up this week. I could use some help on my hitch. Although I can pull the pod with my 2011 Jeep Liberty (with
tow kit), with a regular hitch ball, I decided to opt for the Fastway E2
hitch. After reading different opinions
on the forum, I decided it might be good insurance. When we tried to install it, We found the
hitch on the car (at its lowest setting) is about 6 1/4" too high for the trailer (level). The picture shows the different measurements. It seems like I have two options if I hope to get this hitch to work on my Jeep. Option 1 - The hitch manufacturer makes two additional size of shanks that would give me more drop. They have one that will give 7" of drop that should do the trick. The only problem I am concerned with is that it adds about 6" more drop to the shank so that the bottom of that would be about 5 3/4" off the ground. Will that cause me problems? Option 2 - They also make a bar with about 4" of drop. That is 11" in length and would be about 8 3/4" off the ground. So, I think the second option would be to put a riser kit on the Rpod and get the mid length shank. I would appreciate any suggestions based on your experiences. Are there other solutions I haven't thought of? Thanks in advance for any help. |
Pat
