  New Posts New Posts RSS Feed: pros and cons of risers.
Topic Closedpros and cons of risers.
21grandma View Drop Down
Direct Link To This Post Topic: pros and cons of risers.
    Posted: 17 Jun 2013 at 1:45pm
WinkHusband nixed the ideas of risers.Said gas mileage would decrease significantly. .....anyone noticed this?
21grandma
CharlieM View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 2:07pm
Probably unmeasurable impact on gas mileage. The real decrease in gas mileage happens when you hook up the Pod. My dealer said the risers were worth their weight in gold. He was only half right. They are worth TWICE their weight in gold.
hogone View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 2:16pm
Charlie:  What do you mean by 'hook up the pod'?  Hooking it to the hitch literally due to the weight which obviously reduces gas mileage or hooking up the wiring and using the TV system to charge the pod?  Just want to clarify.  I could possibly see how risers could reduce mileage, as it would be up approx 3 more inches in the air, but your right, probably minimially.
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Seanl View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 2:31pm
I never noticed a significant change in gas mileage between with and without Risers. I had my trailer a year before I put on the risers.
rpodcamper.com View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 3:32pm
I saw no change in mpg after installing the risers. We tend to go to one state park more than others and did all kinds of playing for improved mpg and only found that the position on our kayaks on the roof seemed to help (v shaped)
Direct Link To This Post Posted: 17 Jun 2013 at 4:49pm
Just a thought here.  Everyone agrees (so it seems including myself) that MPG seems to fall in about half (maybe not quite half but close) when pulling the pod.  I wonder if it would be worth the investment to attach an air deflector on the TV to shoot the resistance up and over the pod.  I'm not even sure if those deflectors (hope everyone knows what I mean by that) even really work or make much of a difference, just a fleeting thought..
Jon & Pam
2013 RP177
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 17 Jun 2013 at 5:04pm
I have wondered the same myself. I think it would have to be V shaped though because the TV ls narrower that the trailer.
Goose View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 5:23pm
On a tractor/trailer the airshield on the cab roof and the fairings on the side of the cab do work very well if they are 18 inches from the trailer but not over 30 inches, after that they start to loose their effectiveness. The same holds true with a TV and the POD, you really need a set of fairings that extend a little ways from the back of your TV to start to see any improvement in MPG. Those that have put kayaks on the roof of their TV's have reported better MPG as the kayaks are much like the airshield on a big rig.
I would not think that risers would have much a difference in MPG. Putting flexible side skirts on your TV and the POD may help some, just like on the race cars.   Goose
Direct Link To This Post Posted: 17 Jun 2013 at 7:26pm
We, too, had our pod for a while before we got the risers, and didn't notice any difference.
Discussions with computer modeling in the past showed air flow problems across the curved rear, counter-intuitively.  I think the problem with the pod is less pressure on the front and more suction on the rear.
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 17 Jun 2013 at 7:40pm
I got the best mileage ever on the last trip and it was the first since putting on the risers.  The only thing that helps is keeping the speed to about 55-60.  I loose 5MPG (20 to 15).  If I go 70-75 I loose half (20-10).
2011 R-Pod 177
2010 Ford F-150
