kymooses
Topic: Water Heater questions Posted: 16 Jun 2013 at 8:57pm |
I drain my water heater with a set of low point drains on the side of my Pod. Then remove the anode rod after the water heater is drained completely.
Mine are right below where I plug the power cord in, just under the camper.
RPodWeGo
Posted: 15 Jun 2013 at 12:34am |
I refill my water tank after each trip as I have been told the chlorination in the water will prevent bacteria from growing in a dry tank. Before we head out again I drain and refill in the campsite.
RPodWeGo
RPod 177
04 v8 Toyota 4Runner
Posted: 14 Jun 2013 at 10:07pm |
[QUOTE Ha! D&D, I learned that the hard way. Didn't release the pressure valve when I took out the anode. I got to the end of the threads, the anode shot out like a mini rocket, and I got a fully clothed shower. [/QUOTE] Me too (red faced!!)
2011 R-Pod 177
2010 Ford F-150
David and Danette
Posted: 14 Jun 2013 at 9:51pm |
Originally posted by Kickstart
Originally posted by David and Danette
Unless there has been changes to the water heater you need to remove the anode and drain the water from there. I was searching for a anode rod with a valve for draining that would fit ours but was unable to find one. Make sure when you remove the anode the water pressure has been released. David |
Ha! D&D, I learned that the hard way. Didn't release the pressure valve when I took out the anode. I got to the end of the threads, the anode shot out like a mini rocket, and I got a fully clothed shower. |
That is why I thought to mention it I not only got a bath but a sore knee for a week. I thought in the back of my mind there was no pressure but I was wrong.  Thankfully I wasn't seriously hurt could of been my face if I was bending down low.
2014 Ram 1500 Quad cab
Posted: 14 Jun 2013 at 8:00pm |
True, that will break the vacuum inside the tank too.
hogone
Posted: 14 Jun 2013 at 2:13pm |
Or instead of pulling the pressure relief valve (as sometimes they do not re-seat themselves very well), open up a hot water faucet in the pod which takes most of the pressure away. And don't do it when the water is hot!!
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
Kickstart
Posted: 14 Jun 2013 at 12:13pm |
'12 Toyota Tundra
'05 Sportster (half a Harley)
Retired-We're on Beach Time!
Posted: 14 Jun 2013 at 10:09am |
The other way is to open up the low-point drains (both of them, not just the hot side) and then also open up the over-pressure valve at the top of the water heater.
However, I only recommend doing this at the end of the season. If you drain your water heater and forget to turn off the electric element it will instantly burn out the next time you hook the pod up to power. The water will be fine between trips - in the water heater and in the fresh water tank.
Posted: 14 Jun 2013 at 8:16am |
Removing the anode is the only way I know of to drain the water heater. I don't think draining the main tank will drain the water heater, but I'm not sure.
You don't need to drain the water heater during the summer. You might want to if it's going to be month's before your next trip though.
David and Danette
Posted: 14 Jun 2013 at 5:26am |
