CharlieM
Topic: New Tow Vehicle Posted: 28 May 2013 at 6:10pm |
Jackpod,
Which engine did you get in the Pathfinder?
JACKPOD
Posted: 28 May 2013 at 6:39pm |
Charlie - it's a 3.6L 260 hp, V-6.
Pam and Jack
Abby the Bichon
RP 176 towed with 2013
Nissan Pathfinder
Posted: 29 May 2013 at 7:51am |
Originally posted by Anthony Valenzano
Can you define a long wheel base? The r-pod is short is compared to a lot of 30' trailers, and a F-150 or Suburban is fine for those, so if an F-150 is fine for a 30' TT, what does the wheel base need to be for a r-pod? I can see a RAV4 or wrangler being on the too short side. |
Hard to say what number is the cutoff between short and long, but most truck chassis come in short and long versions. The longer the wheelbase the more stability you get when towing, because the trailer is less able to push the TV around.
Seanl
Posted: 29 May 2013 at 9:03am |
One thing that contributes to sway with the Rpod is that it is a short single axle trailer. The trailer rotates on the axle with little resistance. With a tandom axle trailer there is some rotational resistance caused by the fact that the wheels follow different arcs creating reistance to turning. Thats why an F150 can tow a 30 footer but will get sway with an Rpod. The distance that the trailer wheels are from the TV also makes a difference. It's all geometry and physics.
David and Danette
Posted: 29 May 2013 at 11:28am |
I was told if the trailer is able to rock from side to side that could lead to sway. That is a good reason to have tires designed for trailers with stiffer sidewalls. And the RPods having the wheels on the outside helps in keeping it stable from rocking. David
2014 Ram 1500 Quad cab
Posted: 29 May 2013 at 10:17pm |
Which is also why the pod's tires should be filled to their max sidewall rating.
Colorado Travler
Posted: 05 Sep 2013 at 11:03am |
We just towed our new 178 over 1800 miles including Colorado mountain passes at 45 mph and long stretches of interstate at 65 to 70 mph. Although the 6 cylinder Wrangler has a towing capacity of 3500, it is slightly under powered unless shifting often (we have a 6 speed manual) but with a stabilizer/anti sway hitch all is good. It certainly tracks well, even in high wind conditions. We do intend to add the axle riser to get another 3 inches of clearance to help in steeper campsites.
Colorado Travler
Posted: 05 Sep 2013 at 12:39pm |
Welcome. You can definitely see the extra length of the 178 in your shot.
Posted: 05 Sep 2013 at 12:49pm |
I like the idea of the storage front and rear with outside hatches. How is that working for you?
2011 R-Pod 177
2010 Ford F-150
Colorado Travler
Posted: 06 Sep 2013 at 1:36pm |
There is a bit more room under the R Pod than I expected and it is very cool to have access from both sides in the rear and the door side in the front as well as from under the front seats inside. I actually opened the front inside access hinged panels under the side seats, removed them and cut off about 1.25 inches on the side toward the front cushion. I then placed in an additional wooden cross brace for the support under the cut off portion and replaced the panels. It made it easy to open the side seat panels while the front one is still in place and not scrape against the front cushion.
Colorado Travler
