  New Posts New Posts RSS Feed: low point drains?
Topic Closedlow point drains?
totallystirring View Drop Down
Direct Link To This Post Topic: low point drains?
    Posted: 12 May 2013 at 8:47pm
Hi, everyone! Maybe this is obvious to everyone but me, but I'm not sure where the "low point drains" are on our r-pod. I know about the fresh water tank drain (the black screw-on cap--right?), but when the low point drains are referenced, I'm not sure what/where they are. Even though we've had our r-pod for two summers now, I'm still learning a lot! Thanks!
hogone View Drop Down
Direct Link To This Post Posted: 12 May 2013 at 8:50pm
on my 177 they are right under the left wheel right next to each other, plugs just like the fresh water tank
Direct Link To This Post Posted: 12 May 2013 at 8:53pm
Wow! Thanks! Ours is a 177, too, so I'll bet I can find them easily now that I know where to look! Big smile
dsmiths View Drop Down
Direct Link To This Post Posted: 12 May 2013 at 10:25pm
There should be a decal on the utility side of the Pod. as stated earlier its near the left wheel toward in inside of the body, there should be two.
Dane and Donna Smith
2011 RP-172
lift kit
Direct Link To This Post Posted: 13 May 2013 at 8:52am
Do you live where it freezes in the winter?  If it does make sure you winterize it (or get it winterized) to prevent damage to the fixtures and plumbing.  The low-point drains are involved in this process.
Seanl View Drop Down
Direct Link To This Post Posted: 13 May 2013 at 9:04am
This is what the look like on my Pod. There are black caps that screw on the ends which are off in this picture.
