Page 12> |
compubmw ![]() Newbie ![]() Joined: 27 Oct 2012 Location: Tucson, AZ Online Status: Offline Posts: 10 |
![]() Posted: 11 May 2013 at 9:01pm |
So, Installed my 2000w inverter.
DC directly to battery with 4ga cable through existing hole in floor and a 200amp breaker. I added a new circuit breaker in the AC side of the box and hooked in a cable that plugs in to the AC side of the inverter. Black to breaker, white to AC bus, green to ground bus. Now, even with the inverter off, and its breaker off, if it is plugged in, the trailer will pop my house GFCI thing. Why is it doing this? What am I doing wrong? Please, this isn't a discussion of how long the batteries will last etc. I got a great deal on the inverter and only intend to use it for small things or maybe a minute or two on the microwave at a time, no long term draw over maybe 300w.
2009 FJ CRUISER (ARB BUMPER, Rear Airlift 1000, and some other stuff)
2013 Forest River R-Pod 177HRE (Mods) |
Is this a modified sine wave or pure sine wave inverter? Is the pod plugged into a GFCI, or do you mean the GFCI inside the pod?
Modified sine wave. When the inverter is off, both its 110 and 12 breakers tripped, I plugged the shore power line into the house and it popped the house's GFCI.
Your installation has created a ground path that didn't exist before. I would start with the connection from the inverter to the AC side of the Pod. Lift those connections and see if the breaker still trips.
If the Inverter AC is disconnected, there is no issue.
If the inverter AC leads are lifted from the breaker you installed in the Pod and the problem goes away look for a ground path in the output side of the inverter. Without prints I can't guess at what you have. Doug is most likely more able to help on this, but assuming correct hookup there may be some incompatibility between the inverter and ground power (such as a path to ground that trips your GFCI.
Seanl ![]() Senior Member ![]() ![]() Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
I had to read this a couple of times to figure out what you did. I think you created a ground loop. The ground loop creates a voltage between your ground pin and the neutral in your shore power which trips your cgfi. The way you need to do this is to put in a switch so that you can switch between shore power and and inverter power. This is safety issue as well because the way you have it I think you would energise the shore power cord when the inverter was on.
Thanks Sean. That is what I was thinking but didn't say it well. Like a transfer switch for the generator home hookup so you don't fry the guy fixing the power lines.
Yes. Fried lineman has a really bad smell
You've hit on what I was getting to.
![]() Edit: something else I thought of last night after signing off, in your current configuration you are backfeeding AC power into your inverter when the pod is plugged in which could "let the smoke out". Once that smoke escapes the inverter it is only good for a book end. Another reason to use a transfer switch or keep its output separate from the rest of the pod.
Oh, and by feeding the pod's wiring you will probably also be feeding the converter, which will then attempt to recharge the battery that you are actively trying to discharge with the inverter. That just ends up being a loss of energy for no good reason. Plus the converter will feed 12 volts to the lights, fridge brains, etc. instead of allowing them to be directly fed from the battery... another unnecessary loss. Personally I would wire an inverter to a separate outlet and be done with it. Let the 12 volt system draw from the battery directly, keeping the fridge in propane mode, and then just plugging in my cell phone, laptop, etc directly into that dedicated outlet.
Page 12> |
