  New Posts New Posts RSS Feed: Water Heater Problem
Topic ClosedWater Heater Problem
Direct Link To This Post Topic: Water Heater Problem
    Posted: 28 Feb 2013 at 9:38pm
You will most definitely want to cut an access hole above and beside the hot water heater(under your mattress) to turn your valves on and off.  Mine measures about 4" x 6"  which is plenty large enough to reach and see everything.
Direct Link To This Post Posted: 21 Feb 2013 at 8:37pm
Talk about steaming piles of ...stuff.
coopercdrkey View Drop Down
Direct Link To This Post Posted: 21 Feb 2013 at 5:27pm
I had to oversee the sub-contractors on the condominiums that we now administer.  One of the plumbing
subs had hot water going to the toilettes!
Bob and Joyce
RP 177 "Key Pod"
DocTom View Drop Down
Direct Link To This Post Posted: 21 Feb 2013 at 2:45pm
My water hoses were connected backward when I took delivery, we got great hot water . . .out of the cold faucet!
Direct Link To This Post Posted: 21 Feb 2013 at 2:17pm
To get at it from the top in our 177, you have to remove the half sheet of ply under the mattress.. I intend to cut that end free and secure it separately any day now. Going thru the hatch in the pass through is for someone much younger and "thinner" than I am now. LOL
In fact, that is how I "misplaced" my anode last year.. all my floppin and fittin to reach through there caused mt push it up UNDER the hatch trim.. showed up after the first pull..
Direct Link To This Post Posted: 21 Feb 2013 at 2:05pm
On my 171 the access is from above, underneath the mattress on the left side (to the right as you face the rear).  I assume your water heater is in the same location.  I removed all 4 screws and left them out, the panel doesn't move with the matress on top of it.
Direct Link To This Post Posted: 21 Feb 2013 at 9:50am
Well, sure enough!  Once I finally figured out how to get to the hot water valves, they had all been left in
the 'open' position.  At least the tank was getting water, so I don't think I burned out the electric element.
The water was taking the path of least resistance.
I found an access panel in the storage compartment that was held in place with four tiny square drive
screws.  When removed it gave access to the valves, but required quite the contortionist to reach the
heater by-pass valve.  If I ever get to the point that I need to consider winterizing, I would most certainly
devise easier access, probably via a marine "inspection port" device under the queen mattress.
Anyhow, thanks for the advice.  We'll be especially grateful on our next outing when we have more than
a splash of hot water.
Bob and Joyce
RP 177 "Key Pod"
Direct Link To This Post Posted: 20 Feb 2013 at 5:53pm
The problem is definitely your valve positions from your description.
Direct Link To This Post Posted: 20 Feb 2013 at 4:11pm
Thanks folks.....  I appreciate it!
Bob and Joyce
RP 177 "Key Pod"
Direct Link To This Post Posted: 20 Feb 2013 at 3:05pm
This is the position of the valves to get hot water.
