  New Posts New Posts RSS Feed: Tongue Cargo
Topic ClosedTongue Cargo
Direct Link To This Post Topic: Tongue Cargo
    Posted: 21 Feb 2013 at 8:06pm
The gen. is in a box in the back of the trailer. I also diverted the exhaust to the ground to reduce the noise.
bhamster View Drop Down
Direct Link To This Post Posted: 21 Feb 2013 at 7:31pm
Is that the bottom of your trailer? Do you have other pics of where the generator is installed?
Direct Link To This Post Posted: 21 Feb 2013 at 5:55pm
My gen. is build in, to eliminate noise and vibration I lift the gen. by about 1/4-1/2" with a bottle jack it works great.
Direct Link To This Post Posted: 21 Feb 2013 at 1:48pm
Definitely a good idea to move it to the ground during use.  Otherwise the vibrations through the pod's frame will amplify the sound.  Not a good way to sleep.  Chain it to the tongue for security.
renosteve View Drop Down
Direct Link To This Post Posted: 21 Feb 2013 at 1:32pm
I plan to remove the generator from the tongue when I use it. I'll then let it cool before I replace it. Thanks for the pic and blog reference. They have given me some ideas to chew on.
tsunami123 View Drop Down
Direct Link To This Post Posted: 21 Feb 2013 at 9:45am
OuchAre there any regulations about having an electrical device such as a generator sitting adjacent to a propane tank?  I thought about doing the same and then realized that if the propane tank/hose ever developed a leak, I would be living next to a bomb.  One forum member had mentioned having a varmint chew through the rubber propane hose.
Butterfly_Lee View Drop Down
Direct Link To This Post Posted: 20 Feb 2013 at 9:29pm
I did something like that.
http://podterfly.blogspot.com/2008_07_01_archive.html
The blog has before and after pictures.
LeeStar
Still a work in progress, lots of pictures.
EasyriderSLC View Drop Down
Direct Link To This Post Posted: 20 Feb 2013 at 6:23pm
Direct Link To This Post Posted: 20 Feb 2013 at 5:52pm
Just bought a small Champion generator (L18"X15"X15" and 58 lbs) and I want to carry it on the trailer tongue. I plan to put a metal shelf behind the propane tank and put the 2 batteries in a box and the generator in another one. Has anyone else done anything like this?
