  New Posts New Posts RSS Feed: Portable Ceramic Heater Suggestions
Topic ClosedPortable Ceramic Heater Suggestions
Tars Tarkas View Drop Down
Direct Link To This Post Topic: Portable Ceramic Heater Suggestions
    Posted: 30 Jan 2013 at 10:41pm
  I agree with the ideas that just about any cheap 1500 watt heater will heat a pod just fine.  At 30 degrees we had to leave the bathroom vent wide open to avoid condensation and we were toasty.  I'd choose a heater that had a good thermostat and two heat settings.  Other than that, maybe one with a remote control cause I'm too lazy to get out of bed to turn it down.
  The tip-over switch is probably essential, but I'll bet you'd have to look pretty hard to find one without that feature.
dsmiths View Drop Down
Direct Link To This Post Posted: 31 Jan 2013 at 8:41pm
We purchased an inexpensive one from either Target or Walmart, cant remember. It is a 1500 watt unit. it has blower only no heat, then 1, 2, or 3 blower and a variable thermostat, it also has a oscillate feature. I normally turn the oscilliation off, put the blower on 2 and set the temp to 1/3 or 1/2 or so. We have camped in the fall when the temps dropped down into the hi 20's and there was a hard frost (good white 1/4 inch coating on everything outside) The temps were 72 or 73 inside, and the heater would only run about every 20 minutes or so. We stayed as warm as two bugs in a rug. I think the unit was about $20.00 or so and has tip over protection. very quiet also. The factory pod heater does a good job, but that purge blower will wake you up every time, I guess you would get used to it over time. I like the electric heater better.
Dane and Donna Smith
2011 RP-172
lift kit
Direct Link To This Post Posted: 01 Feb 2013 at 11:22pm
Welcome, Tars Tarkas.
danthoman View Drop Down
Direct Link To This Post Posted: 02 Feb 2013 at 8:53am
Welcome to the forum Tars.
Linda and Dan
Calley the golden retriever
R-pod 177 and a Tundra 8 cyl
Our-pod View Drop Down
Direct Link To This Post Posted: 04 Feb 2013 at 11:00am
As most have said, just about any heater will work.  A few things to consider:
Type:  Don't get hung up on "ceramic" or anything else.  1500w is 1500w.  The differences in fans can make a small difference, but the Rpod is so small that you're unlikely to notice it.
Noise: Smaller heaters use small fans operating at higher speeds.  This translates to more noise.
Thermostat:  Many heaters have thermostats that aren't very good.  One major problem is that the thermostat is too close to the heat source.  I personally have yet to find one that is repeatable.
I'm considering buying this:
http://www.amazon.com/gp/product/B000E7NYY8/ref=s9_simh_gw_p60_d7_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-3&pf_rd_r=1THRZAJ4S7CD5AAXSED9&pf_rd_t=101&pf_rd_p=470938811&pf_rd_i=507846
You can plug any old heater into it and have a good thermostat that is farther away from the heat source.  I haven't used it yet, but it seems ideal for the need.
