Podsible Dream
Topic: Weight distribution hitch Posted: 14 Sep 2012 at 10:26pm |
Are the shanks the same or interchangeable?
Chris and Walt
'10 RP-171 'Free Spirit'
Seanl
Posted: 15 Sep 2012 at 10:10am |
Originally posted by Podsible Dream
Are the shanks the same or interchangeable? |
Yes the shanks are the same size and interchangeable.
this_is_nascar
Posted: 17 Sep 2012 at 10:00am |
I went with the Trunnion style version because someone mentioned it provides more ground clearance than the round-bar style version. Yes, the Trunnion style is more expensive.
"Ray & Connie"
- 2017 R-Pod RP-180
Paige
Posted: 10 Jan 2013 at 3:37pm |
We drove from New York to Florida a couple of weeks ago. There were some frightening times when the RPod started to wag back and forth. We got it under control by using the electric brake,,,but we still are not happy with the sway. We have an antisway on the RPod, the kind you have to crank,,,but it didn't do what we wanted to do. So we are looking to buy an equalizer hitch. My question is,,,they have them for a tongue weight of 600 pounds. We have a 177,,,what is our tongue weight? Is the 600/6000 fastway e2 hitch too much? We have two major trips coming up in February so we want to purchase it and install it. Help?
Paige and Pete
2010 177 - RPug
2012 Rav (six cylinder)
New York & Florida residents
Posted: 10 Jan 2013 at 7:09pm |
I have the 600/6000 E2. The manufacturer confirms that getting one rated heavier than your actual tongue weight is ok (the pod is under 300). I wanted to get something rated heavier for when we eventually move to something heavier.
tsunami123
Posted: 11 Jan 2013 at 10:11am |
 This is a screen capture of your shank...You should be able to adjust the height of the ball shank by a couple of inches if your shank is like mine. The anchor bolts are inserted into slots and holes and held by humungous star washers. I had to move down at least one hole to move the Pod tongue down enough.
Posted: 11 Jan 2013 at 1:38pm |
That was on my old TV. When I got my new one I had to buy a much longer shank - which actually wasn't quite long enough even though it is the one their online tool recommended. You can compare your pic above with this pic:
danthoman
Posted: 27 Jan 2013 at 4:23pm |
Paige - check out the Andersen hitch. I've been pleased with mine. Installs easily, doesn't need special tools or a lot of adjustment. To put on/take off you only have to tighten or loosen two nuts with a supplied socket.
Linda and Dan
Calley the golden retriever
R-pod 177 and a Tundra 8 cyl
duck42
Posted: 30 Jan 2013 at 2:24pm |
Dan: Glad to see your post, I have been considering purchasing the Andersen Weight distribution hitch. Is the model # 3339 the correct one for an RPOD? Did you have to add or take of any chain links in the installation? Wayne
duck42
danthoman
Posted: 30 Jan 2013 at 3:09pm |
I'm fairly sure I bought the 3339 from hitchanything .com for $395 including shipping (I can't find my paperwork). You can call andersen and ask, they were very helpful when I had questions.
To figure the drop/rise needed:
A. With your trailer level, measure from the ground to the bottom of the trailer coupler and subtract 1". B. Then measure from the ground to the top of your receiver (top of 2" square). C. The difference between the first and second measurements will tell you what size drop you will need (below). If the difference is 4 "or less, then the 4" shank will work for your set up (in drop or rise position) If the difference is between 4" and 8", then the 8" drop will work for your set up (in drop or rise position) You can add up to an extra 1/2" if your trailer tongue load is greater than 600 lbs.
I
did not need to add or drop links but I did need to move the surge
brake coupler because it wasn't center on the frame and interfered with
the bracket. I also moved it a few inches toward the pod just for my
convenience. Just one metal screw so it's not a problem. The only
problem I've had is the frame brackets sliding forward because I didn't
tighten the set screws enough.
Linda and Dan
