  New Posts New Posts RSS Feed: trailer harness
Topic Closedtrailer harness
anchorout View Drop Down
Direct Link To This Post Topic: trailer harness
    Posted: 13 Nov 2012 at 10:39pm
x
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 14 Nov 2012 at 1:02am
What are your plugging in to?  My pod plug will only go into my Ford rece[toicle one way.  And it has to be just right.
2011 R-Pod 177
2010 Ford F-150
P&M View Drop Down
Direct Link To This Post Posted: 14 Nov 2012 at 8:41am
Mine will also only go in one way, and additionally it has a blue dot on the "top" side of it so that I don't have to figure out the top & bottom every time.
P & M ... and Comet too!
2012 171 -- The Monkey Pod
2018 Ram 2500
Seanl View Drop Down
Direct Link To This Post Posted: 14 Nov 2012 at 8:48am
Mine will not plug in anyway but the right way. Maybe the vehicle plug is broken. Also it is a pain but I have never seen a factory wired trailer that used the standard colour codes. It is a pain I know but all manufacturers reserve the right to create their own wiring colour codes Ouch
this_is_nascar View Drop Down
Direct Link To This Post Posted: 14 Nov 2012 at 9:07am
As others have already pointed out, it's an issue on your end.  No problem here, as the plug will only mount the TV recepticle one way.
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 14 Nov 2012 at 9:31am
I have dealt with no less than a dozen 7-way connecttors over the years, not a ONE of them could be inserted wrong.
Racer|X| View Drop Down
Direct Link To This Post Posted: 14 Nov 2012 at 7:59pm
Only one-way on my Ford.
Goose View Drop Down
Direct Link To This Post Posted: 15 Nov 2012 at 10:48pm
   anchorout, glade that you got the problem solved.   Goose
coopercdrkey View Drop Down
Direct Link To This Post Posted: 18 Nov 2012 at 6:46am
I don't know.....  I might be able to force the connector in the wrong way,
but it has the locking tab top dead center to help you orient it properly,
(as well as to keep it connected during travel).
Plus, and call me paranoid, I try the brake, both turn signals, and running lights
before every tow and Joyce calls out the AOK.
Bob and Joyce
RP 177 "Key Pod"
Direct Link To This Post Posted: 18 Nov 2012 at 10:57pm
I test every time, too.  If I'm by myself I'll just turn on the hazard lights which will confirm the connection at the Bargeman connector.  If my wife or kids are around I'll do a full brake & turn signal check.
