Footslogger03
Topic: Anti sway or Equalizer hitch ?? Posted: 31 Oct 2012 at 6:11pm |
For the Equalizer, it depends which model you buy. I have the 600/6,000 model, which has a "MAX" tongue weight of 60olbs and a max towing capacity of 6,000. Equalizer also makes a 400/4000 model which is closer to the actual specs of the Pod ...but I wanted a little elbow room.
'Slogger
Livin' the Dream ...'Slogger
marwayne
Posted: 31 Oct 2012 at 7:16pm |
When I bought my WDH I was asked about the weight of the trailer, I replied 3500#, they replied you are good with a 4000/400# hitch, unless you are planing to by a bigger trailer in the future. Since we have no intention to ever own a bigger unit, we went with the 4000/400# hitch. We have no need for a bigger trailer, because we have more cabinet and storage space then we use. We went on a two week trip, didn't have to do laundry, and only went once to by eggs milk and bacon.
Footslogger03
Posted: 31 Oct 2012 at 8:10pm |
We were teetering between the 400/4000 and the 600/6000 for the exact reason you mention ...although I can't see us ever getting a bigger camper now that we've had the Pod for a year. What pushed us over the edge was a "weekend internet sale" at etrailer.com. We essentially got the 600/6000 for the same price as the 400/4000 and figured that extra capacity wouldn't hurt.
'Slogger
Posted: 31 Oct 2012 at 9:29pm |
I have the trunnion style. Coming back from a recent trip I noticed a lot of wiggle at the rear of the pod. Got home and found one of the mounting brackets for the L brackets - the part that bolts around the frame - was loose on one side. Tightened all the bolts up and next trip out the rear of the pod was rock solid again no matter how much I wiggled the steering wheel. Just one example of it definitely working to reduce sway. I have the 6000/600 model - the company stated after an inquiry that going with a larger model would not affect the ability of it to reduce sway or distribute weight.
I've also found a large improvement in ride quality when using the WDH versus not using it.
LarryK
Posted: 31 Oct 2012 at 11:50pm |
We tow our R Pod 177 with a 2006 Toyota Tundra. The E2 hitch makes the ride much smoother and the Pod tracts very very well. The E2 hitch gives me more confidence when towing. I really wouldn't do without it. Also, I was told that the single axle could make the POD more prone to sway. I'm sold on the E2 hitch. We have the 600/6000.
this_is_nascar
Posted: 01 Nov 2012 at 9:05am |
As already mentioned, I have the 800/8000 trunnion version of the E2 that I'll be installing onto my RP-151/Tacoma. I'll report my findings after using it to tow the Pod.
"Ray & Connie"
- 2017 R-Pod RP-180
Bill Ky
Posted: 01 Nov 2012 at 12:55pm |
With the pod having a larger TV and air bags have i don't use the WDH, so I'm only using friction sway control, but in the past with larger TT's I have used WDH with friction sway control. With friction sway control it is recommended to adjust for less friction in rain and snow so the TV and TT act less like one unit. Just being curious do you have to make any adjustments with Equalizer hitch when in rain or snow?
Bill & Marilyn, Tinker Belle (Yorkie), Sparkle (Mini Dachshund) & Tootsie (the turtle) '12 RP175 '07 Dodge Ram 1500
danthoman
Posted: 01 Nov 2012 at 5:04pm |
I've just finished my second 400+ mile trip using the andersen wdh and so far its worked great. I hardly know the pod is back there. Even having to dodge some morons in downtown Atlanta traffic didn't cause any noticeable sway. The setup and take down is surprisingly easy. All I have to do is put the hitch in the receiver, lower the trailer and tighten the two anti sway chain bolts with the supplied socket and I'm ready to roll.
Posted: 01 Nov 2012 at 7:54pm |
Welcome LarryK.
Bill, not sure, I don't remember reading that in the E2 literature. I do remember reading that about friction sway bars.
duck42
Posted: 01 Nov 2012 at 10:23pm |
Danthoman - Regarding the Andersen Hitch, I have been looking a used one, but it has a 2 5/16"ball. Do you know if the 2" ball will interchange in with a 2 5/16" ball in the friction cone receiver? Thanks, duck42
duck42
