Page <123> |
Author | ||
g4royce ![]() Senior Member ![]() Joined: 20 Nov 2010 Location: PortStLucie FL Online Status: Offline Posts: 335 |
![]() Posted: 09 Oct 2012 at 8:51am |
We have a bike rack (for up to 3 bikes) that can go on the TV hitch or where the spare tire is. When towing, the spare tire goes under the dinette and the bikes go where the spare tire is. With 1 or 2 bikes it's ok, but with 3 the sway was very noticeable, and this was on a relatively short (3 hrs) and flat tow to Cape Cod.
ChaiPod
2009 RP152 2011 Hyundai Santa Fe 3.5L V6 |
Seanl ![]() Senior Member ![]() ![]() Joined: 19 Sep 2011 Location: Fredericton NB Online Status: Offline Posts: 633 |
If you knew someone who was handy with metal you could mount a bike rack on the tongue between the LP tank and the Pod over the batteries.
catspaw ![]() Newbie ![]() Joined: 06 Oct 2012 Location: Minnesota Online Status: Offline Posts: 9 |
That would save room for sure. I'll have to look into that since I mounted my 5W solar trickle charger to the jack post. I also moved the spare to the hitch end of the pod by mounting it next to the propane tank parallel to the pod. I could move the pole mount for the solar panel to the upright portion of the spare tire mount. Thanks
RPodWeGo ![]() Senior Member ![]() ![]() Joined: 10 Jul 2012 Location: Salt Lake City Online Status: Offline Posts: 112 |
Seanl,
That's a clever idea and I am going to look into that. I like the idea of being able to see the bikes.
RPodWeGo
RPod 177 04 v8 Toyota 4Runner |
TIDALWAVE ![]() Senior Member ![]() ![]() Joined: 21 Nov 2009 Location: MINNESOTA Online Status: Offline Posts: 315 |
I own a very expensive mountain bike. I also have a large collection of bike racks.
I first tried a spare tire mounted rack. With the bike on the rack I could bounce the bike quite a vertical distance...enough to be worried about the dynamic weight on the rear hitch. The weight of the tire, rack and bike greatly increases when the rear of the Pod is bouncing on a 'roller-coaster' road. I then removed the spare into the pickup TV and removed the tire rack. I replaced the tire rack with a bike rack. This solved the weight problem. But then I realized that the mountain bike was now my rear bumper. I then went to the Pod's tongue...I have a carrier that can be bolted across two beams. But since I dry camp quite often, I carry two batteries and two propane tanks. There was not enough room to install a carrier. The Pod's curved front prohibited putting the bike forward of the batteries. The same with the carrier just to the rear of the propane tanks. I ended up as several others did...storing the bike inside the Pod. I have an aluminum c-channel which I use on the floor (but not attached to the floor) to keep the tires from sliding. I use a couple of bungee cords to hold the bike upright. It has traveled over some really bumpy roads without moving or damaging the Pod's interior. In addition, the bike is secure from being stolen by a thief with a large bolt cutter. |
TIDALWAVE
retireclose ![]() Groupie ![]() Joined: 19 Jan 2014 Location: Michigan Online Status: Offline Posts: 50 |
I have a 2"receiver on the front of my Silverado that I use with a bike rack
Gary and Jill Winters
Bella Golden Retriever 2014 Silverado 1500 2015 R-Pod 179 -(SOLD) ![]() |
francoisfrogpod ![]() Senior Member ![]() ![]() Joined: 24 Feb 2013 Location: Missouri Online Status: Offline Posts: 109 |
For what it's worth, we purchased the bike rack made for the pod. Factoring into our decision was weight distribution and sway. Also, we were told using a different one might void any warranty if it were to cause any damage. It cost a little more, but peace of mind is worth it. I wouldn't want anything to happen to Francois!
Denny and Linda
2013 Pod 177 '08 Santa Fe |
HuronSailor ![]() podders Helping podders - pHp ![]() ![]() Joined: 10 Jun 2009 Location: Owosso MI Online Status: Offline Posts: 704 |
That's the best solution I've heard so far. Can you carry two bikes? Which brand? How does it affect your field of view? Is it legal?
Tars Tarkas ![]() Senior Member ![]() ![]() Joined: 14 Jan 2013 Location: Near Nashville Online Status: Offline Posts: 1452 |
I put the FR endorsed bike rack on the front of my FJ Cruiser for a trip down to the SC coast a few weeks ago. It traveled fine and the view wasn't blocked bad at all, but at night the headlights were blocked and reflected back at me. Not horribly, but certainly annoyingly. For the trip back I put the bikes on the back of the pod and put the pod's spare on the front of the FJ. Much better.
TT |
FJ Cruiser |
I've done something similar with a cargo tray mounted to my front receiver. I added that primarily to carry my generator, but I've used it several times now as a bike rack. I added a vertical 2 X 6 to provide some stability, but 95% of the stability comes from using ratcheting tie-downs. They make it so solid I can shake the truck while holding on to the bikes. I can carry all four of ours, and it doesn't affect the field of view much. It blocks a bit of the road very, very close to the truck but not in a way that it is a safety issue. I agree that the headlights can be a problem - they aren't if I just have the kid's bikes but I'm sure the adult bikes would be partly in the headlight's way. My generator (and its box) sits low enough that it doesn't interfere with the headlights at all.
Edit: this thread shows my cargo tray in action http://www.rpod-owners.com/forum_posts.asp?TID=3689
Page <123> |
