  New Posts New Posts RSS Feed: Winterizing
Topic ClosedWinterizing
Brigs View Drop Down
Direct Link To This Post Topic: Winterizing
    Posted: 06 Sep 2012 at 7:13pm
Had anybody found or have a video of how to winterize the rpod. I know there are written instructions but I feel more comfortable with learning visually
2012 Ford F150 FX4
2011 Rpod RP176T
this_is_nascar View Drop Down
Direct Link To This Post Posted: 07 Sep 2012 at 8:14am
Come on now.  It's just now getting into the camping season.  No talks about winterizing already.  :)
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 09 Sep 2012 at 9:47pm
Well being in the army they decide when I have to close up shop early, so I guess the next question is,
Do I have to use a blow out plug on the city water line, or can I just draw the coolant into the system? I don't have access to an air compressor and I'm running seriously short on time
2012 Ford F150 FX4
2011 Rpod RP176T
Seanl View Drop Down
Direct Link To This Post Posted: 09 Sep 2012 at 10:20pm
I never use a blowout I just draw antifreeze until the water runs pink out of all the taps and the toilet flush. I also open the low point drains to make sure the water is out of there as well.
Direct Link To This Post Posted: 09 Sep 2012 at 11:18pm
So by low points do you mean the 2 just behind the axle near the hot water tank or those 2 plus the fresh water tank?
2012 Ford F150 FX4
2011 Rpod RP176T
Direct Link To This Post Posted: 10 Sep 2012 at 6:35am
Yes that's them all 3. While you mention it you need to drain the hot water tank and leave the the plug out. I also leave the drain plug on the water tank out. Don't worry if there is a little water left in the fresh water tank it won't hurt anything.
Direct Link To This Post Posted: 10 Sep 2012 at 8:49am
Brigs, thank you and your family for your service to our country.  God Bless.
"Ray & Connie"
- 2017 R-Pod RP-180
Direct Link To This Post Posted: 10 Sep 2012 at 9:48am
Wink His profile says that Brigs is in Alberta so that is probably service to our country. Oh well we are allies.
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 10 Sep 2012 at 10:25am
We are all in this together.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 10 Sep 2012 at 11:24am
Full instructions found in the first item on this list:  http://www.rpod-owners.com/forum_posts.asp?TID=1723&title=creating-an-instruction-maintanence-manual
With no compressor and/or the blow-out plug, one alternative is to do the rest of the winterization first.  You may need to use a little extra antifreeze to ensure you have displaced all of the water.  Once the system is full of antifreeze carefully remove the screen on the city water connection, you can then press in the one-way valve with your finger.  That should allow antifreeze to escape to displace the water in that connection.
