mt868
Topic: Fridge in Auto Mode Posted: 07 Sep 2012 at 12:21pm |
I have a Norcold fridge on my 2011 unit. If i put the fridge on auto mode and it has all 3 sources available (gas, AC, DC), is there an order that it chooses from?
I assume it would choose AC first, then gas, then DC?
this_is_nascar
Posted: 07 Sep 2012 at 2:16pm |
Yours is probably different since it's newer, but on mine, there's no auto cutover to any mode. You must choose the mode manually, although it will run on either AC/DC/Propane.
"Ray & Connie"
- 2017 R-Pod RP-180
this_is_nascar
Posted: 07 Sep 2012 at 2:18pm |
Sorry, just saw you did say you had an auto-mode. I'd expect AC is the default, then gas, then DC as a last resort, although you may have to manually switch to DC.
"Ray & Connie"
- 2017 R-Pod RP-180
Posted: 07 Sep 2012 at 5:49pm |
Look for the model number, it might be on a sticker on the inside of the fridge. Then you can look up the manual on Dometic's web site. That will tell you the order.
Posted: 07 Sep 2012 at 8:19pm |
If you search Norcold on the web it takes you to the Thetford site where there is a look up including RV friges. It asks for the model number so you will need that. Mine is a Dometic, so I can't help you.
2011 R-Pod 177
2010 Ford F-150
Posted: 07 Sep 2012 at 8:26pm |
Whoops, I said Dometic because that's what I have, meant Norcold. :-)
