Podsible Dream
Topic: Anti sway or Equalizer hitch ?? Posted: 30 Aug 2012 at 5:12pm |
Thanks,Peter. That area of eastern PA has some nice country. This will be our fourth trip - two to French Creek, once to Francis Slocum up by Wilkes Barre, and now Locust Lake. I am debating, whether to go over 61 or go by 309 thru Tamaqua which looks a little flatter. Looking forward to a pleasant weekend in the woods!
Are you able to make it to the round up in LaPorte on 9/22-23?
Chris and Walt
'10 RP-171 'Free Spirit'
Footslogger03
Posted: 30 Aug 2012 at 5:17pm |
Kind of a shame you have to sell it. Have you looked into the possibility of getting a portion of that vertical piece cut off ? Mine (Equalizer) points downward too. In fact, I bottomed out pulling into the ACE Hardward lot today (big dip at the curve). Anywah ...so far when I am towing it has yet to hit the ground or cause a problem.
'Slogger
Livin' the Dream ...'Slogger
Seanl
Posted: 30 Aug 2012 at 5:32pm |
Originally posted by Podsible Dream
Quit smoking 20 years ago - tho I did for more years than that- it truly was good to have them on breaks in the Army!
Anyway, my E2 is too big, although it is a 600/6000, the shank is L shape, not T shape, so when it points up, the ball is too high, and when it points down, you think Paul Bunyan could carve the Grand Canyon?, the shank just rests about 1 mm below ground level.
So...
For Sale . One slightly used E2 WDH/antisway hitch, complete with 2" ball. Probably best on high growing clearance vehicle. Best obtained by local pickup. Send a PM to ' podsible dream'.
That's to bad. Mine has the T shank I I wish I had another inch or two. The pod is slightly nose up when I am towing.
Footslogger03
Posted: 30 Aug 2012 at 5:58pm |
Originally posted by Seanl
[/QUOTE
[/QUOTE]
"T shank" ?? Pretty sure that's how I would describe mine too - - but one end of the "T" (vertically) is longer than the other. I tried flipping it over but the ball height was wrong. Works best with the long end of the "T" pointed downward ...but I must admit that I am always a bit conscious when I drive over a dip in the road or hit a sudden steep uphill, after a dip.
'Slogger
Posted: 30 Aug 2012 at 9:07pm |
There are about a dozen different shank sizes. I had to get a much longer one for my new TV. I still have my shorter shank, if you measure yours I can compare with mine, which worked on my fairly short minivan. Cheap deal, delivery to the gathering next month?
Podsible Dream
Posted: 30 Aug 2012 at 9:49pm |
Good deal! Sounds like a plan. I'll measure tomorrow and let you know.
Chris and Walt
this_is_nascar
Posted: 31 Aug 2012 at 7:36am |
Well, now I'm worried again about ordering one of these. I thought there'd be enough built-in adjustability to handle just about any setup. Not sure what to do now.
"Ray & Connie"
- 2017 R-Pod RP-180
Seanl
Posted: 31 Aug 2012 at 7:53am |
You just need to get the right shank length there is a tool on the equalizer website for figuring it out. The only reason mine is a little short is I did not have the lift kit on the trailer and I guessed at the ball height after I installed it and I was an inch out. Mine still works I am just slightly nose up on the trailer when I tow.
Posted: 31 Aug 2012 at 9:29am |
Yes, that online tool will tell you exactly what you need.
rpodcamper.com
Posted: 02 Sep 2012 at 12:52am |
here is the link for seeing what shank you need.
