Have You Done Any Mods?
 Post Reply Post Reply Page  <1 4344454647 52>
683 [81.41%]
10 [1.19%]
134 [15.97%]
10 [1.19%]
2 [0.24%]
You can not vote in this poll
Bill-GA View Drop Down
Post Options Post Options   Quote Bill-GA Quote  Post ReplyReply Direct Link To This Post Topic: Have You Done Any Mods?
    Posted: 28 Aug 2012 at 8:57pm
Bill & Bev
13 yr old dachshund 'Elsa'
2011 Toyota Tundra 2WD TV
Footslogger03 View Drop Down
Post Options Post Options   Quote Footslogger03 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 8:50pm
Originally posted by dsmiths
Raymondo, look on the end of the factory short tube and you will see a www. address, I went to it, called them and they sent me a tube that fit my new rhino hose for around $27 bucks, I could not buy the pvc to make a custom one for that, 4 self tapping screws later I was in. I have a 172, the longer holder fit just in front of the black water drain opening, I built spacer to ofset the tube to make it closer to the black water size. It is a lot easier with the Rhino 15 ft hose. good luck.
That's not a bad price for a replacement. Do I understand that the one you got as a replacement is LONGER than the one Forest River puts on the Pods at the factory ? I have a 177 and the factory tube holds a 10 footer but no way could I jam a 15' hose in there. I wouldn't mind having a longer one but I'm not quite ready to buy the PVC and fittings to start from scratch. Do you have any pics of the tube set-up on your Pod ?
Thanks in advance,
'Slogger
dsmiths View Drop Down
Post Options Post Options   Quote dsmiths Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 8:46pm
Dane and Donna Smith
2011 RP-172
lift kit
Podsible Dream View Drop Down
Post Options Post Options   Quote Podsible Dream Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 6:10pm
One problem with my OEM tube was that the hinges on both ends broke, and I' ve been using twist ties to keep the lids on. .
Chris and Walt
'10 RP-171 'Free Spirit'
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 5:20pm
Someone here called that company and ordered a larger size - I think even the diameter was larger.
Post Options Post Options   Quote Footslogger03 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 4:36pm
For what it's worth    ...I bought the 10' (I think it's 10' anyway) Camco sewer hose at Walmart. It came with a grey opaque connector that attaches to the dump valve on the Pod and a 90 degree adapter at the far end. I added a Camco threaded extender (about 4" in length) that attaches to the elbow. The extender gets rinsed and stored in a compartment under the Pod. The rest (hose and elbow) fits in the stock factory tube. Close fit, but it works. I'm just more careful on how far away from the ground pipe I am when I park the Pod. No problems so far and really glad I didn't have to replace the tube. Just wondering though    ...the factory tube has a name on it. Gotta believe they make them in different lenghts and Forest River just happened to chose this one - - just sayin'
'Slogger
Post Options Post Options   Quote Podsible Dream Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 3:32pm
Just finished removing that 15x 14x14inch box behind the shower under the bed in our 171. Cut it down to just about 4" high and 13x12". Makes it feel like there is more room under there. Every cubic foot counts!   Only caveat was that the CW pex pipe has to stick out about 3" to maximize the space. Had to reroute two wires a couple of inches. I then put a movable 5/4 pine brace across the space to support the bed plywood and my not inconsiderable backside. The brace acts as a support when the bed is raised. One of my first mods was to put a 48" piano hinge down the far edge of the bed plywood sheet (at the divider in the compartment) to ease raising and lowering the bed board.
Chris and Walt
Post Options Post Options   Quote Podsible Dream Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 3:20pm
I bought one of those larger diameter white PVC holders from Camping World. It doesn't really fit the pipes either tho it is a tad larger than the stock black one. You have to turn the fittings somewhat sideways. My thoughts have run to using one of those 5" fence posts ( I have one n the garage that was missing its end and connector fittings- so Lowes replaced the whole thing!) and cobbling together some sort of an end cap/door. Saw one on one of the forums, but that gent had used the PVC end fittings and made them fit the square post.
Chris and Walt
Post Options Post Options   Quote techntrek Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 2:09pm
Ouch, I didn't realize that stuff was so expensive.  I kept putting off that exact mod, now I'm glad I did.
Raymondo View Drop Down
Post Options Post Options   Quote Raymondo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 12:16am
The first couple of times I took out my '11 RP171, I didn't use the sewerage system, only the grey water. When it cam to dump the tank, I was dismayed the flex hose was a whopping 5' long stretched out. No wonder it fit well in the tiny under-tongue hose storage tube. I went out and bought the RhinoFLEX 15' "World's Toughest" sewer hose with transparent elbow and locking rings and swivels. Great! Where do I stow it? I wasn't going to fit in the factory provided tub, it's 54" long. I modified a new storage tube from PVC in the rear just behind the grey water tank, drilled and used 2 #14 self-tapping hex screws into the bottom of the tube frame. Added end caps, and I went to put the hose home, and it wouldn't fit! 4" PVC is outside dimension, not inside. I had to go to 6" PVC and redo the exercise at a greater expense. ($60 for the 4", $94 for the 6" solution). Note the 6" PVC screw cap (clean-out) is $114 alone. I didn't but that one, just the friction fit caps and a drill hole & screw to keep it on. RhinoFLEX fits now, the white tube looks good hanging just under the frame ready for camping.
2011 RP-171 Hood River Edition
Towed by Dodge Dakota Sport
