dsmiths
Calendar Event: Antenna 2013 Posted: 24 Aug 2012 at 9:24pm |
yep, Donna and I stock up on the Walmart Cheapie DVD, Andy Griffith show, two and a half men. our Daughter got a Earth series, we have old westerns, some 3 stooges, most of the time its late and dark and we dont make it more than an hour and its lights out. there is something about the fresh air, walking trails, cooking outside, the fire flickering that makes us sleep well.
Dane and Donna Smith
2011 RP-172
lift kit
turncoat3
Posted: 24 Aug 2012 at 5:53pm |
we have found that DVDs are a great substitute for TV stations that you cannot receive. Stock up on some of the classics and enjoy them again.
Ben & Lorrie
2013 Surveyor 264
Posted: 24 Aug 2012 at 9:04am |
I agree, the digital system is ironically not as good as the old analog system. For starters many stations went to lower power transmitters when they switched. Also many moved from the VHF (2-13) to UHF channels which don't propagate (bounce) as well. Finally, the dealer was right and where you could have watched a weak signal with "snow" with analog, digital just errors out and shows nothing. A good antenna with good placement is critical for homes now and is very hit-or-miss with RVs.
curieuse
Posted: 24 Aug 2012 at 8:55am |
Thank you, we have heard that also from the dealer, so I guess we will follow your advice.
Manon
kymooses
Posted: 24 Aug 2012 at 8:46am |
There's plenty of times that we get 0 channels from the silly booster thing when we're camping. I've been in campgrounds where my neighbor says they are picking up a few of the local channels and then we get nothing. Not to say that it doesn't work because we've been places where we can pick up several channels and can get the news and weather which makes us happy. I'd just never plan on or ever hope to pick up anything regularly. It's hit or miss at best.
curieuse
Posted: 23 Aug 2012 at 9:21pm |
Thanks all, we did the scans but no stations were coming in, our dealer said we did the cable scan instead of the antenna scan but we tried both.....and then also said that the new digital technology is tricky if channels are not strong enough nothing comes in.
Manon
Brigs
Posted: 23 Aug 2012 at 9:12pm |
That's a good point with the channel scan I forgot to bring up, every time we go to a new location we have to do a channel scan
2012 Ford F150 FX4
2011 Rpod RP176T
Posted: 23 Aug 2012 at 8:54pm |
Did you rescan for the channels? There should be a menu option for it.
curieuse
Posted: 23 Aug 2012 at 8:36pm |
Thanks Keith, we did push the booster button, our light is red instead of green but still did not catch any signal...???
Manon
Brigs
Posted: 23 Aug 2012 at 8:20pm |
Where your cable line goes from the wall to the tv, there should be a little black push button, make sure it's pushed in ( little green light should come one beside the button) that will turn on the signal booster, that should solve her
Keith
2012 Ford F150 FX4
2011 Rpod RP176T
