Here are some photos of the latest mods I've made to our 177. Sorry that some of them are out of sequence - had some problems during upload ...
Here's the underseat mod with the lids open/off.
Here's what the 22" flat panel TV looks like in place and ready for viewing from the dinnette area.
This is an "off the shelf (no pun intended) shelf made by Rubbermaid that I got at Ace Hardware. I mounted the shelf upside down so that there would be a "lip" to hold things back. We use small bungees to keep everything in place while traveling.
Here's what that seat cabinet from above looks like with the lids on. The lid over the electronics is screwed down to avoid accidental access.
This is an "off the shelf" cutting board from K-mart. I just added legs with rubber feet that fit tightly around the edges of the cooktop. I also added a towel bar.
In the upper left and lower right (on cabinet surface) are the 3M organizer trays.
Here's the bracket that supports the 22" flat panel TV. I reinforced the entertainment center cabinet with molding that I attached to the ceiling with Liquid Nails and then screwed to the existing frame (all of this was done INSIDE of the cabinet for aesthetic reasons.
This is the side of that seat cabinet where I installed the input/outflow vents and the 12V outlet.
