Topic: R-Pod Axle Risers Posted: 30 Jul 2012 at 11:34pm |
Originally posted by GoofyNewfie
are these hard to install...? I ask a local RV company and they advised not to do the mod as it wasn't safe?? can these be installed by the common handyman?
I have trouble parking my pod in my driveway.. it is on a bit of an angle and can't back straight in. I have to go in on an angle over my lawn.. I tore off one stabilizer already, and took a chunk out of my new pavement.. would really like these risers!
You need a new local RV place. They are a factory option on pods east of the Mississippi, and STANDARD on pods west of it.. If you feel comfortable lifting and supporting the pod, and disconnecting (one side at a time) a straight axle, then you can add these.
Seanl
Posted: 29 Jul 2012 at 10:26pm |
Not hard if you have some basic tools and a little knowledge of how to use them. It is a bolt on upgrade so no cutting or welding is required. It took me about 2 hours to complete. I would recommend using an impact wrench as it would be quite tedious to do with a ratchet.
There was a good post on how to do it either here are on the nation forum.
GoofyNewfie
Posted: 29 Jul 2012 at 9:16pm |
2010 RP-172
Tow Vehicle - 2003 Rendezvous
this_is_nascar
Posted: 09 Jul 2012 at 7:52am |
My main reason from the riser was for dumping. It's just too low to use a poo-tank, as is.
"Ray & Connie"
- 2017 R-Pod RP-180
Posted: 06 Jul 2012 at 12:16pm |
Yes, many of us have found that the stock height is just too low. Damaged stabilizers are usually the result.
The E Train
Posted: 06 Jul 2012 at 7:39am |
My '12 Rpod 176T came with the risers. I got positive comments at the campground about the great clearance; but why did they add them in the first place? Was it for the clearance?
2002 Dakota (pulling a) 2012 R-Pod 176T
rudyunknown
Posted: 05 Jul 2012 at 2:46pm |
yes same here only cost me $80 but the best mod ever....
2011 Rpod 171
Tundra
Rudy Reshmi n big Omkar n lil Arjun
sfish
Posted: 12 Jun 2012 at 9:07pm |
I bought mine from forest river. They wanted my vin and said they were vin specific. They were only $75.00 for the ones I bought. I would check with who you bought them from and mention that.
sjf
Posted: 12 Jun 2012 at 5:28pm |
Welcome. I moved this to the Flea Market forum.
Seanl
Posted: 12 Jun 2012 at 1:52pm |
There are more than one Axle Risers. They needed my Model and Vin number in order to get me the correct set.
