  New Posts New Posts RSS Feed: water heater
Topic Closedwater heater
Direct Link To This Post Topic: water heater
    Posted: 20 May 2012 at 10:08pm
I removed the mattress and removed the screws that hold down the plywood under the mattress and left them out.  To access the valves I lift the mattress and plywood.
That's what I did the first week I had my 171.  Haven't had the screws back in since.
Direct Link To This Post Posted: 20 May 2012 at 8:12pm
NO IT IS NOT SAFE TO ASSUME THAT THE HOT WATER TANK IS FULL.  I did this when I got mine last spring, even had water coming out when the hot water handles were turned on.  I turned the propane on, it lit, and my element was toast.  Replaced it for twenty bucks or so.
To check your valves, you will have to either cut a hole in your plywood under your queen bed to access OR as others above have done, take the screws out and lift both your mattress and plywood up.  On the right side you will see your hot water tank and the 3 'mystery valves.'  The handles on the hot and cold lines should have their handles parallel to the water lines. There is another line that runs between these two that  handle should be perpendicular to the line.  Make sure your handles are in this position before firing up the propane or hooking into 110. View Post
Chuck View Drop Down
Direct Link To This Post Posted: 20 May 2012 at 6:49pm
OK. Kind of a dumb question. My dealer did my winterization last Fall and evn though I tried to take good notes I think I missed something. I've looked at my hot water valves and I'm just not sure I know what I'm looking at. They seem to be OK but I'm just not sure. I've hooked up shore water and I have water coming out of the hot water faucets in both the sink and shower. Is it safe to assume that the hot water tank is full and OK to turn on the water heater?
Z-pod
Chuck Janet & Bogie the dog
'12 RP 177
1972 Shasta 1400
2005 Ford F-150 5.3L V8
rex View Drop Down
Direct Link To This Post Posted: 20 May 2012 at 5:30pm
GLAD I DONT HAVE TO TURN ALL THOSE VALVES,MY WATER STAYS WORM MOST OF THE TIME WITHOUT GAS. rex pHp stuart fla.
jrr
dsmiths View Drop Down
Direct Link To This Post Posted: 20 May 2012 at 3:00pm
I did the same as keith and dar, removed the screws holding the plywood down, put them in the lower drawer. I also took a shop vac and vacuumed all the saw dust and loose screws left there, the plywood is not going anywhere when you are setting on the couch/dinette area, and it gives you instant access if needed.
Dane and Donna Smith
2011 RP-172
lift kit
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 20 May 2012 at 2:44pm
I may have to move to Florida...
2011 R-Pod 177
2010 Ford F-150
blissful View Drop Down
Direct Link To This Post Posted: 20 May 2012 at 1:11pm
Thanks, Jato.
No problem since I do not winterize here in Florida....assume these valves are already in the correct position.
Blissful
Direct Link To This Post Posted: 20 May 2012 at 7:01am
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 19 May 2012 at 9:50pm
The "fun" part is getting to the valves.  If you are small and a good contortionist and don't mind tight areas it is easy.  Just loosen the 4 screws to the right of the water heater - in the thru storage area in the back of the pod.  Then you reach your hand into nowhere and try your best to reach and turn the 3 valves.  OR  Lift up your mattress and cut an access hole so you can easily do this procedure and see with your eyes what you are doing.  I cut my access hole about 5 " wide by 6 " long and then cut a 1/4"thick piece of luan to cover the access hole and used 2 wood screws to hold it down
Direct Link To This Post Posted: 19 May 2012 at 9:19pm
Looking at the water heater from the inside, there are 3 valves right behind it.  These are used to bypass the water heater before winterizing.  In the spring, you must reverse all 3 valves to fill the tank again.
