Topic: shower head Posted: 26 Mar 2012 at 2:35pm |
Trust me, you'll do fine even below freezing. Several of us went out in January and it got down to 10 F one night. Go for it!
Damour
Posted: 26 Mar 2012 at 3:14pm |
Campings are not open before may here in Québec
rp 171 , from Québec with not a good english writing lol
Snowbound
Posted: 26 Mar 2012 at 8:22pm |
Check carefully, Damour. Even here in Alberta we have a few campgrounds that stay open all year. We hope to get out during April but that depends on the state of our renovations. B
Tom and Bette
in our 177 "The Gastropod"
TIDALWAVE
Posted: 31 Mar 2012 at 1:05pm |
The recommended replacement shower head by Oxygenics did not have a volume control. I prefer to wet down, soap up, then rinse off. I had to install a volume control on the shower hose. I don't like to stand in the shower and try to turn the water on and off or adjust the temperature.
TIDALWAVE
Outbound
Posted: 31 Mar 2012 at 6:41pm |
Thats odd, because my oxygenics does have a flow control at the base of the handle where it attaches to the hose.
dsmiths
Posted: 31 Mar 2012 at 9:05pm |
My Oxygenics has a flow control at the bottom of the handle, look close it rotates left and right to control the amount of water coming out, also be sure to remove the factory pod flow restrictor where the new hose screws onto the output of the hot and cold valve.
Dane and Donna Smith
2011 RP-172
lift kit
Hodge-PODge
Posted: 01 Apr 2012 at 1:28am |
Mine also has a flow control - just as Outbound and Dsmiths described.
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350
melp
Posted: 20 Jun 2012 at 8:58am |
Bought & installed Oxegenics shower hear. al I can say is WOW  Now longer need to run water pump and hose hook up water for more pressure. Great water pressure with one or the other.
melp
gdfaini
Posted: 21 Jun 2012 at 10:54am |
I see several similar models on Amazon and non look like they have a valve at the base of the head. Which Oxygenics model (15127, 15123, etc.) are you getting? The wand holder also looks like it is meant to attach to a pipe, not a wall.
Glenn
Hyundai Santa Fe <-> RP 173
g4royce
Posted: 11 Jul 2012 at 9:26am |
The showerhead has a built-in flow adjuster where the wand attaches to the pipe. It adjusts from full flow to a slight trickle. It does not cut the flow off completely. An additional cutoff valve needs to be separately purchased and installed if you want to completely cut off the water.
The downside to this showerhead is that while showering, it is easy to accidentally turn the adjuster while trying to maneuver in the small space. The first time that happened, I thought we ran out of water and I still had shampoo in my hair!
ChaiPod
2009 RP152
2011 Hyundai Santa Fe 3.5L V6
