Page 12> |
BlueAudi ![]() Newbie ![]() ![]() Joined: 25 Jan 2012 Location: WA/TX Online Status: Offline Posts: 15 |
![]() Posted: 24 Mar 2012 at 6:08pm |
Hi,
After one outing, our new 177 FR pod went intI the shop for a month (long story) anyway, we have it out for the second time since buying it and are finally hooked up to water. Is there a trick to the hot water heater? We are hooked up to "city water" and rant he hot water through the faucet until all the air and sputtering quit and then turned on the water heater. It's been almost 2 hours and the water is still ice cold! We would appreciate any ideas or suggestions as our dealership is not a good resource for us. Thank you very kindly in advance!! BlueAudi |
2012 RP-177, 'Poddy Mouth'
'07 FJ Cruiser |
this_is_nascar ![]() Senior Member ![]() ![]() Joined: 24 Jan 2010 Location: NJ Online Status: Offline Posts: 466 |
Did you check the plumbing as it relates to the hot water heater bypass? Are you sure that water has filled the HWH? I hoping you confirmed water in the HWH prior to firing it. When you turned it on, did you hear it ignite? |
"Ray & Connie"
Didn't hear it ignite. During our walk-thru, the dealership said to run the "hot" faucet until it stopped sputtering and then flip the rocker switch on for the HWH. They said it had a direct spark igniter. But like everything else we were told, it's really simple and most things have not been so. I'm not sure where the bypass would be.
Thank you so much for trying to help us though. Sometimes it's just nice to know someone hears your frustrations. |
'07 FJ Cruiser |
Pawpod ![]() Senior Member ![]() ![]() Joined: 10 Jan 2011 Location: Regina Sask Online Status: Offline Posts: 137 |
The bypasses on the 177 is under the bed on the kitchen side, you might have to undo some screws.
And here is a link to a video that shows you where they are. Its about a third of the way through the video. Video |
Ready to pod around!
pentachris ![]() Groupie ![]() Joined: 02 Aug 2010 Location: Montgomery, AL Online Status: Offline Posts: 40 |
Did you open up the valve on the propane tank? Do you get hot water if you turn on the switch for electric water heating (located bottom left behind the water heater access panel on the outside of the pod)?
Yes, you start by opening a hot water valve (usually the sink) and letting it run until the sputtering stops. As others have mentioned I'm sure it is your bypass valves. If you aren't sure which way all 3 should point - the ones on the hot and cold lines should have their handles parallel to the water lines, and the on the line that runs between them the handle should be perpendicular to the line. When you winterize in the fall, it is exactly opposite for all 3.
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3358 |
I can relate to your dilemma, Blue Audi. I did just as you did when we first tried our water heater. Waited until the water quit sputtering and flipped on the heater switch. AND then the news- I fried the coil because the bypass WAS NOT open. Anyway, to make the process easier I flipped up the mattress, (we have a 177) took my scroll saw and cut an opening 4" x 10" so I can open those 3 valves easily instead of getting stuck underneath and trying to do it all by feel.
Thanks for all of the suggestions and ideas, folks! It got cold and dark yesterday so we just used the campground restrooms and showers. It's no different than if we were still tent camping. We think we found the access panel under the bed (in the storage compartment) but couldn't locate our multi-tool until late so we are jotting down all ideas and will try again today. Thanks again for all of your support and help! What a great bunch of folks you are!!
'07 FJ Cruiser |
TIDALWAVE ![]() Senior Member ![]() ![]() Joined: 21 Nov 2009 Location: MINNESOTA Online Status: Offline Posts: 315 |
Most, if not all, of the screw fasteners used in the Pod are 'square' head screws. After unscrewing the pump-heater compartment cover, I replaced the square head screws with phillips head screws. I can always find a philips screw driver, but I seem to misplace my square head drivers. Eventually I put a couple of hinges on the wall side of the compartment cover. So now when I unscrew the cover I can swing it out of the way, while I am adjusting valves.
TIDALWAVE
Here is what I did.
Page 12> |
