  New Posts New Posts RSS Feed: Run away Pod
Topic ClosedRun away Pod
czardastx View Drop Down
Direct Link To This Post Topic: Run away Pod
    Posted: 09 Apr 2012 at 8:18pm
In TX it is a legal requirement to cross the chains. I know some of my co-workers have written tickets to people who didn't have crossed chains. It is a safety issue, it makes it safer for you and everyone else on the road to have crossed chains.
Direct Link To This Post Posted: 08 Apr 2012 at 7:41pm
Some people grease the ball and coupler to stop them from grinding, so you could try that.
Gunga View Drop Down
Direct Link To This Post Posted: 08 Apr 2012 at 11:49am
I have noticed on my new trailer that the coupler sticks in the "up" position. When hooking up I have had to raise the tongue back up and physically pull the coupler down. Should I just spray it with WD40?
2012 RP177 Hood River Edition
Toyota Tacoma
Butterfly_Lee View Drop Down
Direct Link To This Post Posted: 07 Apr 2012 at 7:43pm
Originally posted by Iteach5th
Always jack the pod up and watch to see if the rear end of your tow vehicle goes up too. It may look hooked up and may feel hooked up nut always check.  Yes, cross those chains, then double check everything.
If distracted during hooking up, start over.
Good idea..  I always check to make sure the ball is in the socket so to speak.   Just feeling with your finger will tell you.  Secondly I have a EZ equalizer that requires a lift of the tow vehicle by the hitch to insert the WHD rods.
I have had a utility trailer pop off the ball (lucky we were still in the parking lot and the chains held.  VERY Scary.
I also walk around the Podterfly and check underneath before pulling out.
leeStar
Still a work in progress, lots of pictures.
http://podterfly.blogspot.com/
Direct Link To This Post Posted: 19 Mar 2012 at 1:19pm
And make sure they cross UNDER the hitch.  Theoretically that configuration will catch the coupler in a cradle if it comes off.
tpierce220 View Drop Down
Direct Link To This Post Posted: 19 Mar 2012 at 9:52am
Crossing the chains means that the chain from the left side of the trailer gets hooked up to the right side of the TV and vice version so that the chains in essence cross each other into an X pattern.  It will provide more stability to the trailer in case it does become unhitched.
kymooses View Drop Down
Direct Link To This Post Posted: 19 Mar 2012 at 9:47am
Crossing the chains?  Anyone care to elaborate on what I'm sure is an obvious answer, I've never heard of it though!
Folornhope View Drop Down
Direct Link To This Post Posted: 18 Mar 2012 at 1:46pm
Yeah, had done all of the standard stuff that we do...
Class 3 hitch
2" ball.....(don't use a1 7/8" to pull an R Pod)
Electronic brake module
Put trailer on hitch, lock coupler
Raise to make sure it's coupled securely
Cross safety chains
Plug in trailer to truck
I also check to make sure the gas is off to, but thatsme.
Didn't help in this case.  (shrug)
I'll replace the tounge jack stand as well since it got a little chewed up.
I do plan to take the coupler apart and inspect every thing and possibly replace all the parts.  I'm going to have to find out what the torque on that nut is and use some red locktite to help make sure it stays.
Eddy the Escape Pod...177
Ford F150
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 18 Mar 2012 at 1:05pm
Originally posted by Snowbound
Wow! So glad you are OK and thanks for the reminder to check our hitches carefully.
+1!  Great and timely safety topic.
Iteach5th View Drop Down
Direct Link To This Post Posted: 18 Mar 2012 at 11:21am
2011 RP-177
2009 Jeep Cherokee
1982 Coleman Redwood pup
