Guests
Topic: Possible replacement for the A/C Posted: 28 Sep 2010 at 1:29pm |
David, you must have had the A/C from the first batch, with no wall control. Later models allowed you to leave the fan "on", which we do now (someone did figure out how to make the older A/C do the same). The compressor kicking on still wakes me up half the time, vibrating the whole 'pod like a drum. So from a sleep quality standpoint there is no question.
From a $ standpoint, the best option is to leave things as they are, no real "payback" is possible. We spend minimum 20 or so days per year in it, and up to 30, so added comfort for a whole month out of the year is an argument for doing it.
I do think I'll order one for the house first so I can play with the pieces on the 'pod and see how it operates in real life up on the wall of my house. |
Totally understand about the "sleep quality" factor - it sounds like you camp about as much as I do. A month without sleep is not good and takes away a percentage of the camping enjoyment. Yes, although mine was a 2010 model, it did not have the fan option. Drum - YES! 0db of sound to 150db (just kidding). Dometic must be doing something different, as the new one (Coleman) has the controls on the unit and is not near as loud - compressor on or off.
Posted: 01 Oct 2010 at 8:53am |
Quick update, I've continued my research on mini-splits. I found a Mitsubishi model rated at 26 SEER, claiming 160 watts with 2800 btu output on low, which is about 40% less energy than the Sanyo for only 6.6% less btus. Big downside, it requires 208-240 V AC. If I can find a small 240 V inverter (I've never seen one) it might be better for off-grid use.
g4royce
Posted: 13 Jan 2012 at 11:46am |
To dig up this old thread on split-type a/c:
Last year we met a couple who had just bought a brand new Airstream. The guy mentioned that when he was researching RVs he saw that there were RV-specific split-type a/c available now. When we got back home, we tried to research that but didn't find any info on ones designed specifically for RV-ing. Does anyone know anything about these new RV units?
ChaiPod
2009 RP152
2011 Hyundai Santa Fe 3.5L V6
Posted: 14 Jan 2012 at 11:10pm |
Hadn't heard of them, but now I'm going to have to find out! Getting ready to order one of those Mitsubishis I mentioned earlier on this thread, will have it installed by spring.
XJ2202009
Posted: 14 Feb 2012 at 12:18am |
my neighbor had one of these installed in his garage, I believe it was the sanyo, even when the compressor kicks on, is only as loud as a regular window fan. I just got my 176t and was shocked how loud that ac is. when the furnace is being used it kicks the fan on the ceiling too, and even that is louder than the tv at 3/4 volume. is there anyway I can just run the furnace without running the ac fan?
Things I have noticed: FYI...
there is a 2amp consumption at all times, I think (power converter, battery charger, all appliances even turned off consume some power. when the ac fan turns on it goes between 6 and 7 amps. jumps by 4 amps, even at low speed this blows harder than a central ac blower. the ac on low jumps to 12amps
Goose
Posted: 15 Feb 2012 at 5:02pm |
On the thermostat on the wall, go to the fan setting and turn the fan off. I did the same thing a year ago. Goose
XJ2202009
Posted: 17 Feb 2012 at 7:42pm |
Originally posted by Goose
On the thermostat on the wall, go to the fan setting and turn the fan off. I did the same thing a year ago. Goose |
Thanks for the tip, I have that single zone digital thermostat, the only options are, lo hi, auto. based on the manual there are two options of thermostats. I set it to low so that should atleast help.
Posted: 06 Jul 2012 at 9:28pm |
I found two more possible replacements. Like the Mini-splits they would have to be mounted on the tongue, but these are pretty small and light. And they don't need anything mounted inside, just two holes in the side for air in/out. Not too terribly expensive, about the same as a standard RV A/C. Provides heat, too. After looking around at the specs I noticed they even mention "small RVs" as one possible use for these.
http://www.climaterightair.com/cr-2550 http://www.climaterightair.com/cr-7000
Seanl
Posted: 07 Jul 2012 at 8:15am |
I used to have have a home built trailer that had about half the volume of the RPOD and I cooled it with a 5000 btu window air conditioner. These look like window units with a vent and return plenum added. I wonder if someone could mod a window unit? Also did you get an AC with your trailer? If you did how did you plan on filling the hole from removing the old one?
Posted: 07 Jul 2012 at 2:31pm |
Yes, I have an A/C, but the noise is my biggest complaint about the pod. The one on my popup was much quieter. The hole is a standard vent/fan size so it will be easy to replace it with a vent.
Modifying a regular window A/C is an interesting idea. The hardest part would be sealing up the "inside" part since it cant get wet.
