  New Posts New Posts RSS Feed: Gate for TT Storage
Topic ClosedGate for TT Storage
mt868 View Drop Down
Direct Link To This Post Topic: Gate for TT Storage
    Posted: 10 Nov 2011 at 12:32pm
I have a 24' opening in the yard. I want to build 2 - 12' gates that swing open so I can store my TT and boat back there.
Does anyone have any suggestions on how I should build this? I hear it needs to be either steel or Chain Link (with vinyl slats for privacy). Wood will sag or break.
Any suggestions would be great since I have no idea how to proceed with this project.
Direct Link To This Post Posted: 10 Nov 2011 at 1:06pm
Thanks one whopper of an opening!  I'll have to scratch my noggin a while.
Will the gates be over gravel, pavement or grass?
Direct Link To This Post Posted: 10 Nov 2011 at 1:37pm
Gates will be over dirt right now. May put gravel on top later. It was grass but I just had a guy level the area so it could grow back to grass later.
Direct Link To This Post Posted: 10 Nov 2011 at 2:25pm
You might still be ok with wood as long as you add two turnbuckles (with threaded rod) in an X pattern on the back to give each door rigidity.  That's how large barn doors are done.
dsmiths View Drop Down
Direct Link To This Post Posted: 10 Nov 2011 at 2:49pm
You Might check on stock gates that are premade.  If you are near a farming community, we have Orchelins, Rural King and several AG minded stores, they are welded primed metal gates, you could probaly set 6 by 6 in concrete and bolt gates to poles, they are generally steel tubing, but I am sure you could fabricate slats or some light weight material for privacy. good luck.
Dane and Donna Smith
2011 RP-172
lift kit
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 10 Nov 2011 at 6:26pm
Tractor Supply used to be in Texas.  They would have stock gates.
2011 R-Pod 177
2010 Ford F-150
Direct Link To This Post Posted: 11 Nov 2011 at 11:36pm
I dont think it matters much if you use wood or chainlink,(chainlink no upkeep) but I think you should put a spring loaded wheel on the bottom of each gate to keep it from dragging.
thechemist View Drop Down
Direct Link To This Post Posted: 03 Dec 2011 at 8:53am
go to tractor supply, they have very sturdy gates for sale.  My driveway has 2  12' gates on 6x6 posts, been there for 3 years and no sag.
Direct Link To This Post Posted: 05 Dec 2011 at 2:09pm
Welcome, thechemist!
