Page <1234> |
![]() Posted: 28 Oct 2011 at 2:32am |
I pushed the wrong key sorry about that. |
tpierce220 ![]() Senior Member ![]() ![]() Joined: 14 Jan 2011 Location: Oswego IL Online Status: Offline Posts: 281 |
Wow! I'm so impressed--you've done a lot of the things that I would like to do only if I was able as you are.
Hodge-PODge ![]() Senior Member ![]() ![]() Joined: 11 Apr 2011 Location: Calhoun, GA Online Status: Offline Posts: 539 |
Marwayne,
In regard to attaching shelves and cabinets to the R-Pod walls, what did you use? Wall anchors? Mollybolts? I attached a folding clothes rod, and had the hardest time with the hollow wall. I made a mess to tell you the truth, but was able to "fix" it using some wall anchors that would bear more weight. I tried to get close to a 2x4 when I did it, but there wasn't one there. (Not to mention, that I'm no carpenter!)
I guess what I'm asking is how did you attach cabinet & shelf mods to hollow walls so they could bear some weight?
What you have done to your R-Pod is outstanding!
Diane
2011 RP 177, the Hodge-PODge
2011 Mercedes ML350 "A man travels the world over in search of what he needs, and returns home to find it." |
Is that a drain so water on the boat can escape? Double-check the welds on the rear hitch, there have been reports of bad welds cracking there.
Hodge, I used Molly bolts when I added shelves to mine. I put them in every 8 inches or so and they felt very secure. |
Tech, What size Molly bolts?
Outbound used 3/4", I used 1". Pics of mine here.
Hodge-PODge
I have not yet used an anchor or mollybolt in my pod. The inside walls have a 1/8" plywood skin. So drill your holes in the wood bracket countersink them, hold the bracket in place mark the holes, then use a 1/16" bit drill through the skin, use drywall screws coarse thread ( grabers) and screw on the bracket . Dont use a drill or screwgun, you dont want to overturn the screw,if you overturn it it wont hold and you would have to use an anchore or a mollybolt. |
No Doug those are not drains, they are vents, there are 4 of them. I have propane and gas in there, it is for air flow.
Goose ![]() Senior Member ![]() Joined: 24 Sep 2010 Location: Arizona Online Status: Offline Posts: 672 |
All of your MOD's are first class. Where did you find the port hole windows that you put in? I have wanted to put one in the door like you did but Mama has always been against it until she saw yours. Goose
Goose I made those windows, and everthing else you see of my mods. Check my sign.
Page <1234> |
