Topic: Will your Freezer freeze ice? Posted: 03 Aug 2011 at 2:19pm |
I agree kickstart, I installed a fan in the rear comparment of our popup's fridge and still was never happy. Ended up only using it for non-perishable drinks, and took a dorm fridge with us all the time (with a compressor unlike many dorm fridges sold today).
Kickstart
Posted: 03 Aug 2011 at 12:27pm |
I agree with TIDALWAVE. Pre-cool a couple days, place prefrozen cubes in your freezer, and circulate the cold air with an interior battery powered fan. Good advice. Several years ago, I had a trailer with a Dometic fridge that I installed a non-thermostat controlled fan under the outside fridge vent. That helped some, too. Dometic fridges in RPods have a thermostatically controlled fan under the outside fridge cover, but they don't cycle to on until the outside temperature gets pretty hot. They're more of a temp holding device rather than really helping to cool.
RV fridges are notorious for their cooling inefficiency. The three Dometics I've had were all pretty poor. The one Norcold I owned was a little better.
TIDALWAVE
Posted: 03 Aug 2011 at 12:10pm |
I have found the only way to get an RV frig to really get cold throughout is have a battery powered fan running on the bottom shelf. I also pre-cool the frig before I go on a trip. I put a plastic container filled with ice-cubes in the freezer compartment before we leave. We usually then have an adequate supply of cubes to put in drinks but also to help pre-cool the frig.
TIDALWAVE
Posted: 03 Aug 2011 at 11:42am |
Ok, we are still set up in the driveway.. partial shade, and you know the local temps.. running on 30amp AC, and A/C is on, set to about 75 degrees. Fridge is set on max. about a dozen bottles of water in it. Filled little ice maker tray last night. It is the only thing in the freezer compartment, set near the center. Solid ice when I just checked it.
We do intend to use a portable ice maker when ever we have AC available. I go through a lot of ice.
Iteach5th
Posted: 01 Aug 2011 at 8:25pm |
When I put some ice in my little cooler I fill a zip lock bag with ice and put that in my freezer. Helps keep temps down and I have ice for my drink. We usually bring a small cooler for lunch if we leave a campground to see the sights
2011 RP-177
2009 Jeep Cherokee
1982 Coleman Redwood pup
Pawpod
Posted: 01 Aug 2011 at 6:27pm |
One of the ones that go inside the fridge
Ready to pod around!
kymooses
Posted: 01 Aug 2011 at 3:55pm |
Originally posted by Pawpod
Tried freezing pop freezes and after 3 days still not froze. Got one of those fridge fans and they were froze the next day. |
Which type you referring to Pawpod?
Pawpod
Posted: 01 Aug 2011 at 3:52pm |
Posted: 01 Aug 2011 at 1:17pm |
If you must have ice cubes on the go, you can buy portable ice cube makers. I've never owned one or seen one in action...
kymooses
Posted: 01 Aug 2011 at 1:09pm |
I'm thinking I didn't plug the fridge in at home early enough to get the freezer and everything to ideal temperatures before loading it up. In the past I usually give the fridge 1-2 days plugged up outside the garage before loading all of our food. I know how quickly the temp can drop every time you open the door and especially as you're loading it full of your trip's food. I think it just took a while to get back to freezing temp and plus the sun was beating on the fridge side of the Pod all weekend which never helps.
